@thewanted - Here's some data. Kitguru reviewed the stock MBA card here with a power limit of 355W. They tested Horizon Zero Dawn and scored 193 FPS at 1440P Ultimate Quality.
Here's a 7900 XTX TUF OC video I recorded (FPS hit from recording is 2-4 FPS). The TUF OC has a higher power limit of 375W stock, with +15% enabled in AMD Software that takes it up to 431W. With +15%, the power limit was high enough that at no point throughout the bench was the GPU held back by power limit unlike all MBA cards which are power limited.
Proof.
Please note, this was not a unstable overclock. This was a overclock that is 24/7 stable. Technically, the core clock is running stock (3Ghz) and only the memory is overclocked 250Mhz from stock which is 2498Mhz. The power limit was increased from 0% to +15%. To summarise, stock MBA = 193.6 FPS, tuned AIB 7900 XTX scores 242 FPS. An increase of 25%+ in a power limited scenario. 242 FPS puts it 4 FPS short of a stock 4090. Without the recording cost, probably even with a 4090.
EDIT - Realise I am verging off topic here, so will leave it there...
Proof.
Sorry but that water reflective is perfect and correct like in real world, you should be seeing any of them houses in the reflection of water!
