Call Of Duty: Modern Warfare / Warzone (Battlenet ID's in OP)
I'm playing MW2 via Steam and I'm getting this annoying problem where the game isn't even loading up.
I load Steam, select "Play", pop up appears briefly stating its preparing to launch and then nothing.
I've run the "verify integrity of games files" option within Steam and it mentions that 38 files failed to validate and will be reaquired. Still not working.
Anyone else come across this issue?
Im thinking of picking up MW2 on the Blizzard sale. Is the Vault edition worth the extra?
It depends. It comes with 10 hours double weapon xp tokens and the battle pass. If you were looking to Mac weapons quicker then yes it is if you value your time at more than £2.49/ hour :)
The amount of clicks it takes to see what challenge progress you have on your weapon skin is mental (6). Then you have to back all the way out too. Crazy.
I don't want to keep having to update a spreadsheet every time I get a long range kill though. The 25 required for platinum is doing my head in a bit.
Ah its not that in depth, its more like tick it once the challenge is done. individual numbers you'd need to mentally keep track of.
Cheers dude. Are people enjoying the campaign and mp or are people just playing WZ2?
I play everything other than the campaign.
Yeah I did look at it. Am hitting them so infrequently I keep forgetting.
On an unrelated note, on WZ2 you used to be able to mute individual members of your squad by right clicking them in the audio channel. Now I can't see that option, only way I can do it is to leave from the entire audio channel. Am I missing something? Fed up of idiots blaring music or people on console who don't know how to turn their mics off.
You can still do it, iirc press escape, click mouse and your mouse pointer appears you can then right click and mute.
This modern warfare 2 worth a try on PC ? how does it run ? any benefits from getting it on battle.net or steam ? or which is the better platform ? thanks for any help.
Runs absolutely flawless on my 4090 rig, upwards of 180fps maxed out at 4K.
Depends where your majority of games are, if you have a big steam library then buy on steam.
