agree with all of this - by far the quiestest card i've ownedUpdated personal musings on the Nitro…
The Nitro is class gents, I’d highly recommend it if you like AMDs eco system and want the best AMD GPU going. Can’t fault the card in anyway.
My personal sample has the least coil whine of any high end GPU I’ve tested recently. Yes it has some, (anyone who says my high end card has no coil whine at all is lying to you - do not believe them) but it is amongst the quiestest of them all.
The RGB bar is ace, makes a horizontal mount the best look for the card. The Trixxx tool works very well, you can view GPU stats, adjust RGB, enable resolution scaling with Radeon image sharpenin, etc. It just works no silly buggers like other bad RGB software. Note, big shoutout to the Palit/GameRock crew, their RGB software is also top notch.
The card is absolutely silent on BIOS 2, whisper quiet, albeit with a lower power limit Than BIOS1 (default).
@Gibbo, it is going to be criminal if the AIO Toxic ships with the same power limit. It should be at least 500W Vs the 464w seen in the Nitro.
played a bit of Riders Republic & Valorant last night and barely pushed 60c with delta of no more than 18c for the hotspot - fans never spun past 1300rpm - super silent
could barely hear any coil whine either, but I haven't put my ear next to the pc as I'm sure its there. Compared to my Nitro 6800xt that had coil whine that screamed at me
