- 7 Dec 2005
- Wiltshire
Not sure how a driver update is going to short out the SoC power rails and crack die's.
I wouldn’t be surprised if they were refurbed cards.Previous Nv drivers have borked cards :
Don't install the newest Nvidia driver, it's breaking PCs
www.destructoid.com
So its not a new thing ; from the reddit thread though, mining and reflowing is a possible cause - not drivers as the OP suggests
Seems like a logical explanation.
A good chunk makes it sound more epic though3 people and 1 is a system fault.
What with vapour chambers - seems the fine wine, is 'corked'.
Who's to say it's anything to do with vapour chambers? The 6000 series launched over 2 years ago and only now 1 random store in Germany has had a chunk of them coming in with the same issue. The only connection being they all claim to be using the December driver, shouldn't be that hard for people that know how to analyse the driver and see if some sort of voltage protection was turned off that led to this.
I was meaning what with the 7000 series vapour chambers atop this issue. I thought many of this actual issue from that store had seen heat gun use? Was just yankin the chain of those who always mention fine wine, not this issue in particular. Feel sorry for those folk if a driver is found to actually ruin hardware, a BIOS I could understand.
No doubt this will go down as another reason people always say AMD have bad drivers... even though we all know it can't be the drivers causing this.
It no longer works, if you try to download that driver now it will not install if you don't have a rx7000 GPU in your system. But perhaps for a very short period, like maybe one day or few hours the driver file on there did not have this hardware check and people were able to install RDNA3 drivers to control their rdna2 GPU and now AMD has replaced the file
Drivers have killed GPUs before, ask Nvidia. And even windows apps have killed GPUs before
Software are provided AS IS and any warranty or damage claims against VideoCardz.com in connection therewith are hereby excluded.
We sure a driver can cause the gpu to crack? I know it could possibly cause it to fail, but to crack and split open? How would that even work isn't the 6900xt close to the 7900xtx tdp? Could the power delivery be that different?No we don't known
