The 'RX 7800 XT' looks to in theory, be similar in performance to an RTX 4070 TI:
Similar Texture and floating point processing ability. Likely similar bandwidth too, especially if Navi32 has a 256bit memory bus. The pixel rate is reportedly higher on the navi chip.
How similar, depends on the clock rate of the navi chip.
If it is similar in performance, I think AMD would price it high (e.g £700).
AMD Radeon RX 7800 XT Specs
AMD Navi 32, 2430 MHz, 3840 Cores, 240 TMUs, 96 ROPs, 16384 MB GDDR6, 2438 MHz, 256 bit
www.techpowerup.com
NVIDIA GeForce RTX 4070 Ti Specs
NVIDIA AD104, 2610 MHz, 7680 Cores, 240 TMUs, 80 ROPs, 12288 MB GDDR6X, 1313 MHz, 192 bit
www.techpowerup.com
