Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Competitor rules
Here is what mine is getting on TimeSpy - https://www.3dmark.com/3dm/87463366? this is at 1090 on the undervolt and +10% power limit on my silent bios. I had run one at 1125 and no extra power limite and the GPU score was around 29k so a nice improvement from such a small tweak.
Based on looks alone it would be the red devil. Also that Merc card is super long so might have to worry about size a bit more (the red devil is a thicc boy though)
With a few gameplay setting tweaks and the aforementioned undervolt and power increase I'm able to get this for stable gameplay on Cod whilst it still being quiet.
It's almost a doubling of performance from my 3080
So my second attempt at Time Spy and I get this https://www.3dmark.com/3dm/87491221? I used the auto overclock on the CPU which it was is a 0.2Ghz increase. I then upped the voltage on the GPU to 1090 and dropped the core to 2950.
I also didn't have a frame cap enabled either this time or last.
Having never used Time Spy before, is it normal for the GPU power usage to drop down to say 200W/50% usage along with a drop in FPS during it?
Edit: Just tried again going the opposite way out of curiosity, so 3100 on the core and a voltage of 1045 and I now get this https://www.3dmark.com/3dm/87492344?
Apologies if this has been been mentioned before there's 84 pages and I haven't read them all.
Anyone having freezes in Windows?
My 7900XT MBA is faultless while gaming but sometimes browsing the internet is causing hard system lock ups. I swapped out a 3090 for this card ( clean driver install ) and it's only started happening since the swap.
Hopefully a driver update fixes it because I've been otherwise delighted with the card.
Only time i have had lockups was when I was trying to undervolt a little too much or up the ram clock beyond 2650. Been rock solid otherwise drawing about 60w when using the machine for work. (email, chrome + lots of tabs)
Do you notice much difference in performance with 3800mhz ram instead of 3600mhz ram ? I was under the impression when you are not the same as the infiinity clock the performance increase is negligible? I've never really managed to succesfully play around with ram timings and overclocking so hoped it was true
IIRC on X3D even 3200MHz benched similar as higher, only some things showed some small difference. Like a RAM bench, but general usage like gaming, day to day stuff, no difference.
As the kit I'm using (Crucial Sport LT Micron E 2x16GB) doesn't tighten as much as Samsung B die I go for max FCLK:UCLK:MEMCLK 1:1:1, to eek the most out of it.
The B die I have works well @ 3800MHz, will do tighter timings than Micron E. Only issue is on long usage ie 8hrs+ I can see an error or 2. Usually due to heat, it needs more cooling. Where as the Micron E even when my case is as it should be, will stay fine even in high ambient. So I choose the E die for daily use.
