Caporegime
- 13 May 2003
- Warwickshire
Which is perfectly correct and something I always do, either that or Loctite tape. I never get a compression leak with tape on the olive but when I don't use it, I sometimes do get a weep.I used PTFE on the olive not the thread.
Can you take a photo of the fitting?
