- 29 Aug 2010
- Cornwall
So my 8700K is getting on a bit and is a bit of a disappointing OCer (4.8GHz, couldn't get 4.9GHz with 1.3v and temps are high enough as it is).
So I've been considering the options in the title. They'd all cost similar money.
As I see it...
Ryzen 7 5800X3D is decent enough but it's all EOL now and it's performance has probably been surpassed by multiple options now. Plus you can't OC it or tweak it in many ways really.
Ryzen 7 7700 seems OK and would be DDR5 so that's nice. Being AMD there might be a nice upgrade path without having to change the motherboard. However to fit in with the price of the others I'd have to go with 16GB RAM instead of 32GB. Also, the 7700 would really be a stop gap for the 7800X3D (do we know if they're overclockable this time?), so that feels like a bit of a waste.
i5 13600KF seems from the incredibly small amount of research I've done that this might be the fastest overall and best at gaming? Downside here is that to fit in with this budget I'd go Z690 with DDR4, old tech but lets face it with Intel was there really much chance any of it would be reusable? I've probably done more Intel builds than AMD in the past though so in a way it feels a bit dull.
To me the obvious one to rule out is the 5800X3D, despite all the hype it seems to have had in the past it's probably not a good platform to move to now.
So that leaves the 7700 and the 13600KF. Feels like the 7700 setup is more futureproof with more upgrade possibilities but with the downside that the 7700 + 16GB DDR5 might not be as good as the 13600KF with 32GB DDR4.
Am I way off here?
I am a little confused with how the new Ryzen chips work, one review seemed to suggest they boost until they hit 95ºC (or a power limit) but other reviews didn't seem to show signs of them hitting 95ºC. Have I misunderstood something here?
As I see it...
Am I way off here?
