- 25 Mar 2004
- Fareham
Why are they messing around with points. Why not just automatically credit your account?
Because everyone likes points and you can also donate them if you want.
Points are for the benefit of marketing and the company. Just makes it look better.Because everyone likes points and you can also donate them if you want.
Okay if you don't know when peak is because it is agile, how do you know when to load shift to and not to get stung by a higher charge? When do I know if I can cook at 6pm, 7pm, 8pm if the price where the load is high and thus the unit charge is higher falls on that day? Without giving fixed times there is no way to be able to plan when you can move or load shift out a time frame.
Exactly Agile makes sense where you can automate the change in times to being variable when you can draw the requirement via an alternative source. I am not clarvoient yet to be able to guess how the national grid is doing in terms of being on or off peak to know if I can cook and it cost me £1.50 to £5.00 or whatever just cause I got the window wrong.If there isn't going to be a fixed time when stuff is cheaper, frankly I'm not going to partake.
If cheap times are going to jump around the only viable method is to automate your house with a small battery.
This small battery would charge (automatically) at cheap time and discharge off the cheap rate.
However with battery conversion efficiency this probably won't help either.
Okay so we are going to have fixed time periods but they are dynamically given the day before even though the grid has no idea until it happens if that is high or low when it gets to it. Right. And that benefit for everyone needing to check when it is compared to just having it on general fix periods is?Well agile for example gives you tomorrows one day in advance, somewhere around mid/late afternoon.
Its when the pricing tends to come together and why the savings sessions tend to be announced around then. You can follow the NG on twitter if you want to see their announcements on risk coming
I am sure they could find a way of averaging over shorter periods of time, like a week to give some more certainty, without allowing the incoming vs outgoing to get massively out of wack.
Also don't use any social media so everything would have to be given from the supplier to myself via their portal to follow.
Why isn't there a law where all electronics now had to be smart.
Link it all to the smart meter and bobs your uncle.
Things like freezers could switch off during peak times and back on at cheaper times and obviously on when required same for fridges.
The washing machine and dryer could be set to switch on when prices are within a range.
Same with smart plugs ability to have them come on when off peak for doing things like charging batteries. It's an really simple to implement as well just needs to be pushed on people.
Battery conversion isn't that bad actually. AC to DC is like 95%.
If cheaper units you store are 50% of normal price, then it easily makes sense, maybe less than 50% even achievable depends.
95 percent?
I thought it was something around 70?
But that could be because I'm using what I get from my dc to dc power banks!
95pc sounds high.
You're going grid to battery
Then battery to home device.
If it is above 90pc my mind is blown
I doubt it's above 90%. I had a Victron inverter/charger back in SA, which is a pretty decent brand. Charging efficiency was around 90-92%, and discharge efficiency was about 95% - so overall about 85%, but the batteries also had losses - round trip efficiency of the order of 95%. So I reckon that takes overall efficiency down to the low 80s.95 percent?
95pc sounds high.
They already do it, its not "hard" for them even if its hard for you to imagine.
They aren't accurate to a kw but they will be to MW levels, or certainly 0.1GW levels.
Are you the sort of person who considers weather forecasts to always be wrong?
Maybe you should consider expanding your horizons a bit then. If you follow stuff like the NG you will see how they are far more capable than you think.
So if NG cannot predict a day in advance how do they decide when to do the sessions? Ponder that for a while.
I already explained and you said you understood why variable pricing is better. I guess you didn't.
The peak generation (the real peak not the nonsense 8am-5pm carp) costs massively higher rates, genuinely massively higher.
We all have to pay for that, we all pay in effect the average of all the costs added together / the number of units produced.
If we can pull the peaks down (the real peaks) those most expensive units will not be produced.
The total bill for all the units will be lower.
The more we eliminate the most expensive units the lower the total bill gets.
If we encourage people to use the cheapest they can that assists in that shift. As people shift the profile flattens since it will adjust to reflect supply and demand.
Now supply isn't fixed, its quite variable, this dynamic changed from the 60s when the fixed pricing use all you want when you want made sense.
Is archaic just like some peoples thinking.
We got 4986 points for the 23rd, not sure why because at that time no one is ever in so we would have used the same as we normally do. I know you get a bonus sometimes for being in the top 10% or something as we did for a couple of previous sessions.From 16 points on the 12th dec, 136 points on 19 jan to 520 points on the 23rd, all over the place, but still something for just doing a click.
24th is still calculating.
1272 points £1.59 currently.
