Damn... Okay man, no worries. I've tried to find anything on google to see if someone had anything similar, but nothing came out.Not popping up after I run it, though what do you mean by navigator?
They should pop up in the navigator I think.
@Woodsta888 Yes, even if DLSS is on or off, I get the same results.
The thing is, even the main menu of Metro has stuttering for me...
I mean, chrome or firefoxNot popping up after I run it, though what do you mean by navigator?
dark alley wallpaperThanks man. I can see you only got 2 stutters, thats pretty good compared to my benchmark. Tbh I don't know what else could it be...
Have you tried running the power limit at 75%? I found when i run my 4090 at stock it constantly comes up saying its hitting the power limit - which can drop my frames massively. Dont really get any performance loss at 75% in games (maybe 1 or 2 frames) but its much more stable in games.Thanks man. I can see you only got 2 stutters, thats pretty good compared to my benchmark. Tbh I don't know what else could it be...
How can I do that, MSI Afterburner?Have you tried running the power limit at 75%? I found when i run my 4090 at stock it constantly comes up saying its hitting the power limit - which can drop my frames massively. Dont really get any performance loss at 75% in games (maybe 1 or 2 frames) but its much more stable in games.
Yes.How can I do that, MSI Afterburner?
did you try the lower power limit?
Hey man, sorry for the late answer. I just did RMA to the GPU... with the new one it works like a charm! so yeah... it was a faulty 4090 as I was expecting (already talked it in other forums about this like this one)
But yeah, if someone over here encounters heavy stuttering in almost all games like it happened to me, it probably is an VRAM problem. It seems like a lot of VRAM chips where faulty in the first batches or something, idk.
Thats good you got it sorted anyway!Hey man, sorry for the late answer. I just did RMA to the GPU... with the new one it works like a charm! so yeah... it was a faulty 4090 as I was expecting (already talked it in other forums about this like this one)
