So, in all honesty, going from a 7900 to 7950X3D do you think one would notice much of a difference?
Depends on many factors, what GPU and what resolution?
I don’t think it would make that much of a difference. Going up a GPU class would make more of a difference.So, in all honesty, going from a 7900 to 7950X3D do you think one would notice much of a difference?
7900XTX @ 3440x1440Depends on many factors, what GPU and what resolution?
7900XTX @ 3440x1440
Fair enough. That's good to know. Thank you for your answer and advice.At that resolution I don’t think you will see a big uplift. Minimums will improve no doubt. If you look at reviews of the 7900 at 4k even with high end GPU‘s there’s not much in it performance wise.
Z690 and Z790 are 99.9% identical. Main difference is official support (QVL) for £500+ 8000Mhz DDR5 kits, which not many would buy anyway.
13900k running flawlessly on a Z690 hero here
Obviously AM5 will last longer, though it's a much more expensive platform. DDR5 + AM5 vs DDR4 and £85 board, no comparison from cost point of view.
Pickup a cheap 7600 from OCUK in the meanwhile, sensible thing to do is the test your parts to ensure none are DOA.
Can't wait for all the useful 1080p 700 fps benchmarks
You do know how to use benchmarks don't you.
If you want 1440p 120fps then you need a CPU that can achieve 120 fps in your desired titles / engines. If in the 'useful 1080p' tests your CPU can only manage 60fps then no matter what GPU you pair it with you are maxing out at 60fps and you are short of your goal.
So get the CPU that does 120+ fps in the titles you want, find a GPU that does 120fps in the titles you want at your desired resolution and then pair the two together.
To be honest it never occurred to me that people did not understand this because I thought it was blindingly obvious.
To me it's even simpler than that. You just want to remove any potential GPU bottleneck to see how well the CPU performance scales.You do know how to use benchmarks don't you.
Entirely depends on the games you play. AAA fare and GPU matters more. Sim racing / flight sim and you will see differences unless you have a really weak GPU. If you want to improve Stellaris tic rates or Cities tic rates or the tic rate of other games then you should see pretty big uplifts. 5800X3D was 60% faster in Stellaris tic rate than the 5900X and you see similar gains in Factorio. Football Manager is another candidate where X3D might be disproportionately faster due to the cache but nobody tests it so we don't actually know.
I'd love someone to run a quick FPS test on it lolthis ? MSI PRO H610M-B DDR4 not sure I would wanna pair anything with this
I have had worseThat is the saddest looking motherboard ive ever seen![]()
The only way to test a cpu is to remove the GPU bottleneck hence people testing at 720p. What confuses some people is just that “I play at 4k, who plays at 720p snnnort” Pointless testing a CPU at 4k. It would be like testing a cars bhp on a rolling road that is capped at 200bhp. No one would have a clue what their car is capable of without removing that cap.You do know how to use benchmarks don't you.
Considering do this now myself. As if you wait to upgrade to the X3D about 3 months after launch when supply vs demand is better the "launch" premiums will be gone and get a better overall dealI couldn’t be bothered waiting until April anymore so I ordered a 7600x for £234. At least that way I can make sure my motherboard and 4090 actually work and then look to upgrade to a x3d in the summer.
