Yea max brightness is blinding.
I obviously need a trip to the Opticians as I have everything on Max brightness
Your eyes are going to get burn in, never mind the screensI obviously need a trip to the Opticians as I have everything on Max brightness![]()
Can a windows laptop connect to this? Is it over tb? I would like display and Audio.
Getting mixed reviews off of google/yt.
Did anyone go for the nano texture screen ? If so is it worth it?
I'm tempted to get one of these. I have a Mini with 2 thunderbolt ports and could really do with some more ports. I also want some speakers for just watching YouTube etc. I'm thinking instead of buying a hub and speakers to just get one of these and give my son my dell monitor. The TB ports on the back I would want to plug in my SSD's for back up and Time Machine. Are there any issues with these getting disconnected when your Mac goes to sleep?
Thanks and no issues with my mrs using her windows laptop for work?My TM backup SSD is connected to the monitor, everything works just fine.
Good luck getting it to work with Windows, there's a huge thread on Macrumors about it, it almost certainly won't just work out of the box with a Windows PC.
It was plug and play with my USB C Windows laptop but I couldn't change the brightness. It was locked to max which is eye searingly bright. I'm sure there's a workaround that involves switching to Mac to adjust the brightness and back again.
I'd be tempted to wait for the Samsung S9 5K 27" monitor if you want better cross OS support. Q1 is rumoured for a release date. I'm certainly keeping my eye on it.
Samsung takes on Apple and LG with its own 5K display for creative pros
It’s the same size and same resolution as the Studio Display.www.theverge.com
