Don
- 20 Oct 2002
- Oxfordshire / Bucks
I don't think there will be a problem tbh
Unfortunately the Mcguuires Ultimate Compound hasn't helped much. It looks the same tbh.
Anytjing else I can try? When I run my finger over it I can't feel anything so surley it's just on the surface
What did you use to apply Mega UC with?
You can increase the cut with these types of products depending on how soft or coarse your applicator is/was.
Megs UC with the right applicator and technique should be enough to remove that defect safely, usually German paint is on the harder side too meaning a super soft applicator is unlikely to achieve much regardless of product.
Edit: So would definitely give it some more elbow grease with a firmer applicator before buying more products if you haven’t already.
I just used a normal house cloth to apply then dry away with micro fibre. What should be using to apply it?
Did a really deep clean of the interior this weekend.
Love LRC Leather cleaner and Protector, actually smells of leather. P&S Xpress Interior for the plastics and vinyl, and AB Direct Alcantara although I don't like the smell of this stuff. I see LRC do an Alcantara cleaner so I'll definitely order some of that.
Finding the Dyson V8 very underpowered for car cleaning, and I'm sure the battery is on its way out after 5 years of ownership.
Looks like a wire brush, lol!Did a really deep clean of the interior this weekend.
Bought a new battery for ours, was only about £40. Has worked well. That said, yes, it’s weak for the car.
You can buy them direct from Dyson. Been thinking of doing the same, our V8 is about 2/3 on a full charge now. Never bothered with it for the car though unless it's a quick clean up. Use a karcher wet dry vacAn OEM battery? Where from? Didn't realise you could swap them out! Might get one of the more powerful ones, although I have the charger for the V8 mounted to the cupboard wall.
Ha! It does now you mention it, I can reassure you it's the LRC horse hair brush. It's quite a narrow brush head which is great for cleaning awkward places like where the leather dash meets the windscreen, the gear selector and door cards.
Do you have a battery tracker?I wouldn't buy OEM Dyson batteries. There are enough quality Samsung cell 'no-brand' clones.
I am on a 4-year cadence, as evidenced:
Amazon fills my hole <3
Had my car ceramic coated a few weeks back - any recommendations for a good (and reasonable) shampoo thats ceramic friendly?
Ive also had my car given a Gtechniq Ceramic coating and asked the same question as you on the detailing world forum. The response and subsequent reviews praised CarPro Reset Shampoo.Had my car ceramic coated a few weeks back - any recommendations for a good (and reasonable) shampoo thats ceramic friendly?
What do you guys use to wash the salt out from under the car? Any special attachments you can recommend? I have a Karcher K5 FWIW
CarPro Reset and Reload are great for keeping a ceramic coating topped up and in prime condition.Ive also had my car given a Gtechniq Ceramic coating and asked the same question as you on the detailing world forum. The response and subsequent reviews praised CarPro Reset Shampoo.
