Hello all! Been lurking this thread for the last few days so I decided to join just to share my experience.
Initially got a 4080 FE and had it paired with an RM850x as well as a RM1000x that I purchased in anticipation for a 4090. The 4080 FE was virtually silent under full load.
Managed to get my hands on a 4090 FE and have tested it on a RM1000x and a HX1000i PSU.
Unfortunately, the 4090 FE has some coil whine. Not the worst I have experienced but still disappointing to see on such an expensive card. I am currently running a 13700k, MSI Z690 Edge mobo, and a 3440x1440 @ 100hz monitor. With the 4090 I enable DSR at 1.75x which is some resolution I can’t even remember, so a majority of the time I am running the card at 99% usage.
What puzzles me is that my coil whine is completely different in every application. I’ve only had the card for a few days so I haven’t tested a vast amount of titles but here is what I have gathered..
Cyberpunk max settings with DSR @ 1.75x, DLSS Quality, Frame Gen on, psycho RT. This particular case produces the loudest coil whine in this GPU. I will link a video.
Hitman 3 max settings with DSR @ 1.75x, DLSS Quality, RT on the highest setting. Some coil whine, practically inaudible unless I mush my head right up against the mesh opening of my case and listen for a few minutes. Sitting just a few feet away from my PC I can’t hear it.
Battlefield 2042 Ultra settings, DSR @ 1.75x, RT on. Practically no coil whine that I can tell.
Furmark with GPU at 100% usage and I hear nothing, same goes for Timespy.
This is a very poor quality example but this is the coil whine when playing Cyberpunk. You can hear the difference when I leave the main menu and return to the game. And yes, my computer sounds like a jet engine. I plan on disabling all of my case fans to get a better capture of the coil whine when time permits.
Enjoy the videos and music that you love, upload original content and share it all with friends, family and the world on YouTube.
youtube.com
