- 28 Dec 2017
- Beds
Bad joke made by my boss in 2007!Just curious as to why Jesus needed it?
It’s not the foam which does the cleaningI can never get a decent foam. Is there a special trick.
Using kit from direct hoses and polar blast from autoglm
I also think if you have a slightly less powerful pressure washer changing orifice size on the lance a can help most come with a 1.2mm orifice you change change this to a 1.1 or lower like a 0.9. My K4 full control does okay with a 1.1I can never get a decent foam. Is there a special trick.
too wet today
had a good opportunity to clean the black trim and do the engine bay today
I've always wanted to do the engine bay, today I thought id do it..
I mean that looks like a great little pressure washer you have. I would still switch to a 1.1 orifice as that unit has the same stats as my k4 basically, and I noticed a difference on mine when I changed it over. I would definatly try to work out your panel impact ratio as a rough estimate I generally use 155ml product to 500ml warm water and I get good foam that works well but I usually use a citrus prewash first them layer the snow foam onto that.I use this
Lance
And this
Pressure washer
for reference.
I don't think its the kit so much as me not knowing how to use it I suspect.![]()
My detailer mate said you get better results with no prewash / a dry car.I mean that looks like a great little pressure washer you have. I would still switch to a 1.1 orifice as that unit has the same stats as my k4 basically, and I noticed a difference on mine when I changed it over. I would definatly try to work out your panel impact ratio as a rough estimate I generally use 155ml product to 500ml warm water and I get good foam that works well but I usually use a citrus prewash first them layer the snow foam onto that.
My detailer mate said you get better results with no prewash / a dry car.![]()
see I have tried both ways no citrus and with I i get better results with it on a heavily soiled car. I just do what works for me
properly salty and winter covered car and bilt hamber touch-less snowfoam got rid of probably 90% of the muck of it! very impressed. That's the only pre-wash I use these days. I often see people pressure wash their cars first before applying snow foam, do not do that.. it reduced the effectiveness of the foam becausei runs off/thins out when on the paintwork.
