Hopefully there is some stock in OCUK today.If OcuK have stock and I get lucky, perhaps. I'll be trying a few UK retailers to get a couple.![]()
I'm not sure the 7800X3D is going to be that similar in perf to the 7950X3D it has 700mhz less boost and that's a 12% freq loss. That has to have an impact on overall performance. No doubt it'll be good value for money though but for the top perf 7950X3D looks to be where it is at.
I'm liking the look of the 50-75W less power used than the 7950X and some people seeing 20C lower temps also.
7800X3D only has 8 cores, so anyone running AAA games with a few background apps open will see performance benefit from a 12 or 16 core model. These reviews are 100% clean systems, nothing installed bar benchmarks/drivers - all 'normal' people would have some background apps going on, all of which use more cores.
Yes, it's very niche and basically limited to one or two games, in very specific scenarios and settings.Very few games will max all 8 cores fully. I'm not sure the performance benefit is going to be much to write home about.
Most games run really well on 6 cores, I doubt 8 will be a limiting factor apart from extreme user edge cases.
It's hard not to be impressed tbh, it has lower power draw than the 5800X3D with double the cores and a lot more performance.I feel like I'm pickling myself mentally, the power consumption of the chip has really impressed me. Wondering if its worth swapping my bits for full amd. My cpu is yet to ship but I have the mobo and ram.
Someone tell me its going to be okay? Lol
If you're not using a 4090 though, you don't really need a Zen4 X3D for gaming IMO, as the returns are too low to justify.
Power consumption is really the only benefit overall. Even then there are some videos out there that show with some tweaking you can lower the KS's power consumption for very little performance loss if it is a big concern to you.I feel like I'm pickling myself mentally, the power consumption of the chip has really impressed me. Wondering if its worth swapping my bits for full amd. My cpu is yet to ship but I have the mobo and ram.
This video might help. It's a K CPU and the KS is supposed to be more efficient right? Maybe I have that around the wrong way. Even tweaked it won't match the power efficiency of the 3D chips.Yeah, I would have loved to see an undervolted Intel comparison, I mean aren't the stock cpu settings overkill? Are we comparing factory highly optimised amd chips to Intel chips with non optimised factory settings?
What memory were these tests using on the 13900k? And if they were stock it’s making the 13900k look even worse.Yeah, I would have loved to see an undervolted Intel comparison, I mean aren't the stock cpu settings overkill? Are we comparing factory highly optimised amd chips to Intel chips with non optimised factory settings?
The techpower up benches at least used 6000MHz and cl36 on both systemsWhat memory were these tests using on the 13900k? And if they were stock it’s making the 13900k look even worse.
The Techpowerup video used the same speed RAM as the Ryzen which I wouldn't use if I was buying a KS but it is what it is.What memory were these tests using on the 13900k? And if they were stock it’s making the 13900k look even worse.
All I can tell you is even the Cinibench scores on the 13900k I’ve seen are all very low compared to mine which is undervolted. My CPU is not a very good example either. Some of the tests are using curve optimiser etc but leaving Intel stock.The techpower up benches at least used 6000MHz and cl36 on both systems
? Stock vs Stock is fair. If AMD tune their CPU's more efficiently out of the box and Intel don't, then this is Intel's problem.Yeah, I would have loved to see an undervolted Intel comparison, I mean aren't the stock cpu settings overkill? Are we comparing factory highly optimised amd chips to Intel chips with non optimised factory settings?
Both sides benefit from tuned RAM, Intel more so as it can go higher, but the differences are not huge.Ram speed doesn't seem to make much of a difference does it? Or is my memory failing me?
Stop it Dave, I've started to agree with a few of your posts recently and this is most unusual behaviour for you.? Stock vs Stock is fair. If AMD tune their CPU's more efficiently out of the box and Intel don't, then this is Intel's problem.
The reviews need (and indeed do) represent what a typical end user can expect, with an out of the box/stock configuration.
