But that's my point exactly. The 3d isn't any better than the normal 7950x in efficiency. The only difference comes from the stock power limits. The same way, the 13900k isn't much different to any zen 4 cpu in terms of efficiency. All of the difference lies in the stock configuration. The site club386 tested both at 125w power limits, and at most the difference in efficiency was 19% in vray, and 10 to 15% in other multithreaded workloads. So best case scenario, zen 4 is 19% more efficient in heavy MT workloads than the 13900k. It's not a small difference, but it's not a leap or a gap either.I feel like you ignored all context. The point was the 7950x3D. We don't have all the data so used performance data for the 7950x vs 13900k. Which as pointed out in the stuff it was wining it was 7-8% performance. Since the 7950x3D is within reason similar peformance to the non x3D but at a significant lower power usage then it would be the ideal out the box user case.
Now check what the difference is in content creation between the 2. Not only is the 13900k MUCH faster in premiere pro, photoshop, lightroom etc, it also does it while being 50% or more efficient. That difference is actually - if you think about it - bonkers. If you do this test performance normalized, the 7950x will be consuming twice the wattage of the 13900k for the same performance. For added context, the youtuber im linking was suggesting zen 3 cpus non stop for content creations, he isn't just an intel fanboy or what have you
INTEL & AMD both lied! REAL WORLD power consumption is MESSED UP
Intel & AMD have both 'lied' about their real world power consumption. Here's the Truth:Sponsored Message:Whokeys 25% discount code : TN20 Windows 10 Pro O...
