- 16 Jan 2003
- Nottingham
New update and app update, 15.1
Era speakers launching in 4 days according to the email I’ve just received from Sonos.
The 100’s won’t, the 300’s will.The Era 100s could be worth a look depending on what they can offer from an Atmos perspective.
Current setup is Arc + One surrounds and a sub. If they can enhance atmos in some way ill be in.
Adding other speakers i.e a sub / rears isn't going to improve your 'centre' channel. You'll create a nicer sounding system no doubt with enhanced bass from the sub and some rear effects from the ones but if you're struggling with clear speech then either try re-run the room EQ or consider an alternative.
I'm pretty sure you don't a crossover set with the sonos stuff like you do with a HC amp so you'd still be running everything through the beam and just have the sub giving a bit more low down ooomph which may make it sound a little fuller / better but won't really improve vocals.
The beam really is just to improve up on a teles built in speakers, which it does, but will never really give a decent home cinema experience!
Like you I still recommend adding a sub for a better sound with the beam - but just don't think it'll improve the speech.
