- 2 Sep 2013
Looks like the extra cores may affect performance more so than keeping just the v cache ccd active
Do we know what the power consumption is like between the two different approaches?
I don’t like all this turning things off. It should work as intended. I hated having to do this in Star Citizen on my 13900k. It was literally unplayable though without disabling e cores.
This is why I want the 7800. Having to disable/enable worry about parked cores…the whole thing is so inelegant. It’s like some kind of computer oddity from two decades ago.
But you don't have to do anything ot worry about disable/enable. If the CPU is parking cores itself to an 8-core then you are already at the 7800x3D and then if something uses more cores it un-parks itself and uses those cores as needed. If you want to shift a game from one CCD to another then you can do so via the xbox gamebar if you feel it is not on the optimum core but if you manually pushed any game that is not on the x3D CCD0 then you will loose performance in some titles more than others.This is why I want the 7800. Having to disable/enable worry about parked cores…the whole thing is so inelegant. It’s like some kind of computer oddity from two decades ago.
Exactly I litereally posted this like 30mins after video done. People are rehashing the same discussion with zero concept or wilful misunderstanding tbh.
I think it's exactly the same issue as before; not enough info being passed around. Good explanations are not often around enough or buried under a mountain a lot of click bait.Exactly I litereally posted this like 30mins after video done. People are rehashing the same discussion with zero concept or wilful misunderstanding tbh.
I figured that out far too late lol. I don’t like Process Lasso, so that was a God send.You can enable legacy game compatibility mode in bios and just hit scroll lock to park ecores on the fly. No need to reboot to toggle
The interesting thing about that slide is its showing performance for the 7950X as if its got a full size iGPU, really?
Not everyone reads pages and pages. Let’s be honest if all posts that are off topic were deleted, there wouldn’t be many left. Once the discussion turns to how much more money AMD has made and how they manufacture their shoe laces and where, it’s turn off time.Are we in a time loop? This is the same discussion we had about it when the last video was posted where people had a direct quote about why and how it all works.
Interesting. Do you have this game to test?The tech press didn’t bench it, but apparently the 7900X3D is absurdly faster than the 13900K in Tarkov according to an owner of both CPUs. Tarkov was always quite favourable towards the 5800X3D from memory.
Reddit - Dive into anything
www.reddit.com
Edit He’s referring to this video.
Nope not my cup of tea, but I’d bet my life saving I’d get better performance than his 7900 X3D.Interesting. Do you have this game to test?
www.reddit.com
Awesome, thanks! I think I'll need to tweak the PBO settings. Did you test the -28 with P95 or something to verify it's stable? With my previous 5800X there was no way I would have gotten that much of a undervolt.Yes.
1. Disable Second CCD.
2. Disable SMT.
3. Clean OS, minimal background apps running.
4. 360 AIO +Liquid Metal +100% fan speed.
5.Latest Chipset drivers, game mode enabled in windows and Game bar updated and enabled
6. Tuned CPU, using curve optimiser -28 all core. PBO enabled, max power limit scalar x10.
7. Tuned memory, 6200MhzC28 64GB dual rank, with FCLK at 2167mhz.
8. BIOS memory options, Disable memory power down.
I use y cruncher 1-7-0 to test cpu stability and 25 runs of TM5 1usmusv3 and 5 runs of Anta777extreme profiles to check stability.Awesome, thanks! I think I'll need to tweak the PBO settings. Did you test the -28 with P95 or something to verify it's stable? With my previous 5800X there was no way I would have gotten that much of a undervolt.
sadly this is AMD for you. make everything more hassle than it needs to. its baffling they still cant work this out. every product the same. just make it work without the extra messing about. its why most just pick intel nvida cause you plug in it works!This is why I want the 7800. Having to disable/enable worry about parked cores…the whole thing is so inelegant. It’s like some kind of computer oddity from two decades ago.
