Massive thread reply incoming lol
That would be super handy mate, no pressure though, just let me know. I'm happy to buy a half decent one when Ican find out if 90mm actually "fits" me better overall on the current setup, I think it will be just the difference I need but only one way to find out!
I was chuffed with the bargains to be honest, the shoes are also MEGA comfy in my initial test and cant wait to give them a test ride.
The pedals (after checking this morning) are lighter than my old banged up 105 - 5800 pedals that I intended to use, so going to stick with the Botranger Elite ones to start with
The shoes weight difference is also significant, not that im a weight weenie at all, but after picking them up I couldn't believe how light they felt so I thought I would weight them.
My pair of old trusty shoes were 820g for the pair (inc clips) and the new ones are 515g for the pair with cleats so that's nice!
@Musty Pie I have a confession to make! Totally forgot over the weekend and then this week too (can I blame old age?!). One of those annoying things - delayed the bit of non-critical weekend bike maintenance until monday night and then only had time to kick the tyres. As soon as I reach for any tools I should've remembered - but just hasn't happened. Sorry! This weekend ok?
I definitely do have a Giant Connect 90mm one as my Defy they fitted a shorter stem when I had a pre-fit and it came with a 100mm. Switching the bars+stem over to the Contend (warranty replacement) a few months back I found the reach slightly 'less' and the fact the frame is plain white wanted some colour and had a
100mm Ritchey stem on the shelf I'd bought (but the colour didn't match my
Diverge) I'd never fitted swapped them over...
Rapha sale on Sportpursuit is not too bad. I've taken a punt on a GoreTex Pro Team jacket. Ripped my last jacket trying to take it off in Wales last year trying to take it off
Do they rip easily or was the last one a ShakeDry (which I know does)? Great price on them, just the colour has always annoyed me... Like much of the current Rapha range colours they're just too 'off' basic/primary and personally I don't like that greeny/teal colour.
The womens one is a more normal Blue that I do like! Typical. I do have moobs can I get away with a womens jacket without being a laughing stock?! Actually no chance with my waistline, I'm easily a Large in anything Rapha non-stretchy in male sizes, so probably an XL in womens then the arms would be twice as long as mine!
Had a ride out today where the weather took an unexpected turn and had a massive hail and rain storm got back home and washed the bike. When i went to take the rear wheel off to put the bike back onto the turbo trainer the rear derailleur had a bit of lateral wobble when i was starting to take the rear wheel off. I stopped and let the derailleur reset back to its usual position and i noticed that the hanger had a fair amount of movement from the frame where the wheel sits into the frame where its attached. Checking the screw that holds it i noticed the screw wasn't very tight and tightened it and everything seems ok.
This is on my Canyon endurace had it about a year, theres only one screw that holds the hanger to the frame as the screw says only tighten to 1nm should i consider taking out the screw and putting some loctite blueon the thread?
Defo locktite it! Not the sort of thing you'll want to be tightening very much (hopefully), but also the screws they use on them quite often are small and flimsy... So once they work loose once or twice they're pretty much wrecked and will not stay tight again! I actually fitted a 'tight' washer on mine when I replaced it, so could tighten it up further as it's also gripping more of the edges of the hole in my frame than just the boss on the hanger. My giant Defy was even worse for it, even tinier screws and 2 of them so it would 'wobble' even when fitted tight, so would then work loose more than the bigger single one on my specialized (which I've only tightened 4 times in 7 years - but 2 of those in the last 18 months, so know when it starts it's unlikely to get 'better' without some help).
Some of you may remember the problems I had with creaking last summer. I finally got the rear wheel bearings replaced in around October and it was almost perfect. Well, in the last month, they started back up, getting worse and worse. Annoyingly, just before they made noise, one LBS (my local just having closed down) that fixed my Di2 issue told me the rear bearings were going, but I said to leave them as I half didn't believe them and half just wanted to eek out more milage, knowing I'd not long replaced them.
I'd been talking with one of our club guys who does a lot of maintenance and he was adamant the bearings were fine and had me trying all other sorts of things (thought it was spokes related), but today as we stopped at our usual place (which is also the LBS I mentioned earlier) I decided to ask if they would have time to look at some point in the week. "Bring it in now, we'll take a look". They said straight away they could tell the bearings were knackered. It would take 30 mins and they'd do it for me now...
They did the front and the back. Wow... what a difference. The ride home felt like a new bike, gliding along. It almost felt at times it was accelerating when I wasn't even trying. I wondered if it was a plaplacebo-typeing, but some of the numbers suggest I really was going quicker for less effort. I only checked a few segments, but maybe the one that was the most eye-opening, last month 18.0mph at 289 watts and today 19.3mph at 237 watts!
Great you got it sorted quickly while you waited... But also pretty poor that they've not lasted a single winter! Must be some pretty poor 'protection' on them to stop ingress? Have you done anything to try and help them? For me I'll always coat both the outside bearing surfaces (but especially those below wheel endcaps) with some 'waterproof grease'. Yes it may mean some dust and crud gets in there and can 'look' dirty, but that layer is stopping water getting into the bearing itself - so they last longer (but also easy to pull the endcaps off, wipe them clean and then apply more). But bearing brand/quality can almost be directly linked to bearing life, especially in UK conditions. Our wheels likely see more cold and water than many others. Also partly why I like replacing my own, picking up better quality bearings for £12-20 when on deals then the knowledge/skills myself to change them in hubs/BB's makes them more of a 'wear component' and easy to choose to replace as the cost is far lower. Get that 'gliding along' feeling sooner/easier rather than 'soldering on'!
I've been trying to tell myself this. Feel slow in recent months and I know the rear bearings feel screwed.... Cero wheels I got in May :/
Cranks seem to keep loosening too.. bit weird. Bottom bracket feels fine when I pull them out but I'll tighten the cranks up and then a month or so later I can feel lateral play.
#bikegettingtooold
Have got that crank one too, even after tightening a few weeks back so know it's not the BB (as that generally comes with a click as some grime/grit gets in there)... Bit annoying isn't it! Kinda waiting it out with the miserable weather, as soon as things a big warmer and 'nicer' get some new bearings in. Wheelsmfg bb so easy! More annoying is the BB on the turbo bike also feeling rough as know that's a shtty Shimano plastic BB71 or whatever they are so need to get one ordered. Seem to recall they're 2 difference sizes and last time I got it wrong, but then also frame has changed since so don't 100% know what is right!
@Roady Are you still looking for a crankset? ~£90 for 53/39
https://www.probikekit.co.uk/bicycl...ings/shimano-105-r7000-chainset/11746895.html
Some decent Shimano deals at Merlin, including ~£38 for most 105 cassettes.
Winter feeling again this week, just at the time I was thinking about finally setting up my VEL 50mm wheels bought months ago, as March tends to be when I try wean myself off the turbo and begin the "outdoor season!"
Saw there was an update for the free MyWhoosh turbo app the other day, quite graphics intensive, previous update around Xmas for app prevented paired up turbo from reading power to move avatar in-game.
Thanks for remembering me mate! The 53/39 has been similar price (think 95?) for a while... Really don't have the legs for that and been holding out for the 50/34 to drop but not seen it change much. Annoying! They're less 'metal' so should be cheaper to manufacture?! Surely price fixing the 53/39 is what the Pro's and really good amateurs use, so should be more expensive!?
I tried to do a search, so dont hang me for asking!
Whats everyones preferred lube choice? Im just starting to read up / watch on Zero friction cycling test results, ive just ordered some Tru Tension Banana slip Tungsten stuff to try, wondered what everyone else was using?
Finish Line Green. Quite a dirty lube, but amazing staying power and wet weather resilience in UK conditions. But am working my way through a bunch of
Mucoff wet weather (stupidly bought 2), although it's good stuff (smells amazing!) and has OK staying power. In the colder grotty grim weather it tends to thicken up. Maybe it reacts a little with salt/cold? Basically the 'road gravy' stuff you clean off is pretty solid and almost like a solid 'glue' mixed with grime on your components (think cassette/jockey wheels/chainrings). Takes quite a bit of effort to get off. Funnily enough the mucoff degreaser is one of the few things which makes removing it slightly easier...!
Inside on the turbo I want the quietest one I can (thats reasonable cost) as any noise reduction is very welcome there.
I always use a 'wet' lube indoors, there's more chance of it drying out indoors and me not noticing (ride with headphones in). Outdoors will switch depending on season (but have still yet to find a dry lube I like! Think I'm on the C3, the yellow one).
Done!
Although i was too lazy to get up this morning to actually take it for a maiden ride!
Also, capturing the cleanest this will ever look!
Looks awesome! Very shiney! Yes agree with the others the 'twist' looks slightly strange, but not a bad strange...! Would be very interesting for someone with some knowhow to test just how well that works performance/flex wise! Although does remind me of
Lynskey who do a twist on some of their Ti frames and is a bit of a design flair known to them and makes them pretty recognisable. But Ti is totally different material behaviour/flex/stiffness wise...
Only downside is the Garmin mount i've bought feels rubbish. As i've gone integrated bars i ordered something off Ali Express, but whenever i rode over a bump it kept rattling on all but the smoothest tarmac. Unsure if it's the weight of the Garmin 1030 or something else. Looking again now on Ali Express i can see some others which look a bit more rigid/better designed. But would appreciate any actual recommendations.
K-Edge.
Crazy price (£46!) and really hated myself for spending so much on a mount... But at the time (2017) they where one of the top 2 rated for solid/stable mounts for a 'combo' to mount the camera below and stopping vibration. It is very strong and been rock solid so have got my moneys worth (even after initially hard to stomach).
Unrelated... Paid off our mortgage last night! Woohoo! Sod all savings left, but that feeling now that I can possibly legitimately save some money and put to one side to spend on a bike with no/little guilt...! Know realistically that won't happen - so many things we've said we'll do 'when the mortgage is done'. But there's the possibility of it! Who'd have thunk it at 42 I'd have it paid on a fairly medium sized 4 bed house, with a family and kid. When 17 years ago I barely had enough to live on (<6k a year being self employed), had to move back to the parents/family home for extra work and really questioned what I'd done with my life. Miracles can happen - but more so than that - so much of it is down to luck and chances. But also even changing things slightly like your own mentality can massively improve your wellbeing and mental health. Be strong everyone, I'd say my stubbornness at times has helped me almost more than anything else.
