Yeah I was very lucky, but I'm hearing more and more of quiet Suprims.
Could just be my age, but yeah, as far as I can tell my Suprim is completely quiet. Given it was the model that seemed to have some of the highest reports of whine I was sure it would have some, so it was quite the pleasant suprise.
My watercooled Inno3d card has no fan noise at all.
Just tried the super glue method on a PNY GeForce RTX 4090 card using the guide here: https://www.techpowerup.com/forums/...ix-coil-whine-coil-choke-noise.294015/page-12
Only did the ones in red.
Sadly no difference. Still same old chainsaw/buzzing coil whine like noise
And undertvolting and even setting power limit to 50% does nothing.
At least the Gigabyte Gaming OC responded a bit to be quieter to undervolt and was almost silent at 50% power limit even though clock speed tanked to 1300MHz. And was definitely much better undervolted with 2300MHZ clock speed.
PNY card it tanks and still has the chainsaw noise coil whine anyways with like almost 0 improvement
What do people think of mine? I think it's quite loud... it's completely stock, when the volume of the audio when the video is inside the case is what i hear with the panel shut. My phone doesn't seem to pick it up well though
Seems very loud especially at the end.
Does not seem good at all.
Yeah, it's quite bad. Tried witcher 3 and cyberpunk with the same result. Sigh... guess I'm going to have to send it back
It's crazy, the amount of money we are spending and we have to struggle with this.
Jensen says "Thanks and HaHa suckers"It's crazy, the amount of money we are spending and we have to struggle with this.
I capped mine to my monitor refresh rate of 120fps, it wasn't running at insane frames.If you’re going through a large amount of cards and they all feature similar traits it’s not that you’re the unluckiest person in the world, it’s that it’s within normal variance and “normal”.
It’s like people who exchange multiple ps5’s and say they all have whine, how unlucky they are.
It’s what the psu does in the ps5, and high end graphics cards are going to exhibit some noise, especially at high frame rates.
I’m not saying there aren’t some that have excessive noise, but I do feel certain people have unrealistic expectations and are NEVER going to find a card that exhibits the noise or lack of noise levels they are expecting.
