******Official Star Citizen / Squadron 42 Thread******
lol......
And the patch is live, if anyone's still bothered at this time.
Also an update on the Vulture
Nope. I went to bed lol
I'll check it out tonight. I'm out all day today
Cool little video they released and they already go adverts playing on YT with other bits and bobs showing.
Haven't tried yet but I've got a free weekend so will likely have a go tomorrow after the initial influx.
Got to front of the queue and then it was like nah you cant play. Might just wait a few days lol.
It gets stuck on character, retrieval and readiness
Just keep trying, if you can handle it, after a few more attempts i eventually got in, once you're in you don't need to queue anymore on attempts after that.
My highest queue number was near 10,000, some were way higher than that, this was 3 hours after it went live.
Cant wait to download 3.18, hopefully i can get in a bit easier and the servers arent as busy....got to wait for the wife to play her stupid disney dreamland first though lol
I wouldn't bother yet, just tried and keep getting this .
i have it downloading now, prob wont try and get on until later though, do i have to delete anything after i have downloaded the update to 3.18? or can i just start playing? i didnt bother trying 3.18 when it was being tested and have gone from 3.17 to 3.18
Update itself was fine as expected, 14gb ish. However a while later when I tried to launch it sit's as Entitlement Processing and eventually gives me a 19004 error. Login failed, try again etc.
https://status.robertsspaceindustries.com/incidents/8d58dff6
Partial Outage
Mar 11, 15:30 UTC
We are currently investigating an issue preventing users from logging into the RSI Issue Council.
More updates to follow as soon as they're available.
[2023-03-11 Updates]
1530 UTC - Initial Notice, investigation in-progress.
Yep this is what i get everytime, hopefully it gets fixed soon as just want to play lol
Should be good to go, No need to do anything other than update it.
Now for just the damn login issue to be fixed ......
I NEEDS TO KILL @humbug :devil.gif
Oh, did I say that out loud, oops ;)
Well just spent 3 hours? in there, did some reclaimer hull scraping with a crew, so far so good, nice performance, smooth, no issues.
Got in myself but was totally different experience for me...more bugs than ever! from trying to buy things to retrieving the ship, performance seemed a little worse but not by much, idk, maybe it was the server i was in but Europe server was usually the best for me before.
Will jump back on later, hopefully i get a better experience
On performance, you have a similar GPU to me. https://www.techpowerup.com/gpu-specs/msi-rtx-2070-super-gaming-x.b7142
Mostly its fine, it doesn't like the planetary volumetric clouds and sometimes even on moons my frame rates are little over 30, i need to upgrade it. but at 1440P its fine for now.
I have a Ryzen 5800X, that's pretty solid, and 32GB of RAM, that helps too, it is better than 16GB, i used to run 16GB and noticed a marked difference when running it with the 32GB kit.
I think you would see a difference if you dropped a Ryzen 5700X in that motherboard, currently £210, and a cheap 32GB kit, Team Group Vulkan Z 3200MT/s is the one i'm running, currently £80.
Your Ryzen 3800X would be better than the Ryzen 3600 here, but i think the 5700X would be much closer to the 12700KF than it is the the 3600.
Also, make sure the game is installed on the fastest drive you have.
111 FPS :D in the *****... still, triple digets man. And look at the frame time graph, just a perfectly flat line.
Ignore the 0% on the CPU threads, MSI OSD is somehow incapable of reading what my CPU is doing.
