Incredibly jealous I ordered on the 16th and it’s been radio silence since mine left gls.Ordered 17th, delivered today, happy with that. Now to get it up and running and install a few games..
Has anyone bought a JSAUX backplate recently? Was curious if they fixed the issue with the slight gap on the top near the charger port. If not, any idea how thick the thermal pad is? The new colour options looks really tempting but the slight gap would bother me a little too much, so planning to either swap it with a thinner pad or just completely remove it.
. It definitely helps smooth out the fan ramping up and down in extremely demanding games as the plate takes a while to heat up, in some games I could hit 85c for a moment before the fan would really ramp to the 6000rpm+ range and cool things back down before it then ramps up again.the 512gb one has an anti glare filter on the screen (some like it, some dont).What's the downside of the lowest spec version apart from storage space
I'm thinking of getting 2 1 for me and the wife?
aside from storage capacity, the larger you go the faster the storage (dont think there is much in it in a practical sense).
other than that the 512gb gets a slightly different carry case and some unique digital cosmetic pap.
all 3 consiles are essentially the same.
This is a good question if anyone can share their experiences as I am in this position re Deck or Laptop etc?Whats it like when you plug it into the TV and use a controller, Or would i be better off just getting a gaming laptop ?
Seems like a good deal. Had a chance to try it?Played about with it a fair bit today. Installed a few emulators, played dead rising 3, mad max and civ5. Everything ran great with zero issues, all were installed on my samsung 512gig sd card. Fantastic bit of kit.
Got this dock arrivng today, on promo with 50% off.
Yes you can switch signed in accounts quite easily.Can you have different steam profiles on them?
I use the Steamlink on my iPad but sharing this with the kids could be handy when we go away.
