Difficult to know.
You're right the article doesn't talk about IPC, and yet the slide does, but it also qualifies that with (1T) its as if it the slide was made by someone who doesn't understand what IPC is, qualifying threads is irrelevant when quoting IPC, you would only do that if you were including clock speeds which are usually different 1T to nT.
Some people use IPC and clock speeds interchangeably, which is idiotic, they have no understanding of it.... given the poor quality of todays tech journalists i'm going to assume they are idiots and agree its probably a combilation of clock speed and IPC.
IPC has seemed to become a bit of a "buzzword" these last couple of years, ever since Ryzen came out and AMD were going on about the increase in performance because of it. And people have just seemed to jump on the word without fully knowing what it means.
It seems pretty unlikely though that we get 22-30% IPC gains on top of the gains from 3nm. That would put the overall uplift at some pretty insane levels, and quite frankly I dont think thats possible unless a lot is coming from the cache and their X3D chips become the norm, getting rid of the regular chips and just using the 3D V-Cache tech across the board
 This could be worth waiting for to jump to AM5. The non-x version. I'm already waiting for the new 140mm Noctua fans so a bit longer.
