- 14 Apr 2014
- Hampshire
Need a longer hose anyway so hoping I can find a replacement which works with my pressure washer and stubby gunWill do some research.
Direct hoses
Direct hoses![]()
@Janesy B also recommended direct hoses.
Thank you.
My dilemma is having bought a stubby gun which does not fit the old style Karcher C Clip - But hopefully I can find a C Clip style hose to my pressure washer with a new style other connection!
I’ll look in the morning, I can’t be the first person to run into this problem![]()
Send them an email and they should be able to make a hose with those connections![]()
I need to give my Merc a proper clean this week, it is frankly disgraceful and has not has a proper deep wash for 'some time'.
Question, what are you chaps, chapesses and those in between and around using to clean the plastic in your cars. Think the protector strips on the door entry and also, what can you recommend for cleaning alcantara as my wheel with 20k miles of hand gunk now needs.
Thanks!
Thanks!
