I don’t know you personally so there’s that.I am, it was one of my criteria currently!
The audio is also good enough so 99% will use that. I remember when boards where just that, they had nothing integrated, it was less wasteful but also less convenient.
It's so hard to find a motherboard that doesn't have something I don't like.
Yeah, they seem to either use a bad ethernet chipset or they share PCIe lanes with other things I'll potentially want to use or they don't have heatsinks on all the m.2 slots or they don't have enough fan header or the fan headers don't provide enough power or they have dodgy BIOSes, etc.Mood. I was about to flip flop again to the Asrock B650E Taichi... but it's got a fan on the VRMs.
Why? It's over 2000 amps of power delivery, it will not get hot with any CPU on the market today. It could possibly take the heatsinks off and still not get hot. Why on earth would they add a small fan, whose quality control will be low and potential for noise high? Is it just a mechanism to make the board be annoying in 2 years time so I buy another one?
One of the M.2 slots doesn't have a heatsink on it, but I only plan to populate 3 m.2 slots anyway and use the 4th to upgrade a drive if needed.
My worry with the Asus boards is the network chipset is that dodgy Intel one that seems to be causing a lot of issues.
How much slower are the m.2 slots on the chipset? I was planning on putting a couple of WD SN850X drives there.
My memory isn't on either of the QVL lists...
Doesn't the TUF use the chipset for the bottom two m.2 drives too? WiFi and audio are both of no concern as I don't use them.The ASUS TUF X670E-PLUS WIFI has the Realtek controller if that helps (0 issues for me so far, using ethernet+wifi), and the 'better' Realtek audio than the MSI MAG X670E Tomahawk.
My only criticism is the bios, I updated to 1408 last weekend and had a whole host of issues so I rolled back. This may just be an AM5 thing, an ASUS thing, or whatever I'm not sure, but I'm all back to working good and will leave it on 1406 for the forseeable future. Memory @ EXPOII (even though it's not QVL - G.Skill Trident Z5 6000Mhz CL30), Undervolted with a -20 PBO curve on all cores and temps/wattage are perfect. It doesn't have an LED display for 'error' codes, but it does have multiple different coloured LED's that go through the 'POST' steps to at least indicate what component could be at fault.
I looked at the b650e-e but the price difference between that and the X670E-F was so small (~£30 I think when I looked) that I thought I'd go with the X670 (which I believe is being delivered today, but I'll probably send it back). But now I'm concerned that they both use the dodgy Intel Ethernet chipset.More I look at these boards the more the B650 E-E Strix stands out. For £300 for all the features it has 4 nvme (two gen 5, two gen 4), post code screen, 4 Sata, quick release, 2 pcie gen 5, 6+ fan headers, 3 argb headers etc. Nothing is worth the extra £200+ for the 670 range up.
Not had any problems with the Intel Nic on the B650E-E, I only run it at 1Gb so have not tried it at 2.5Gb. Think a fix/workaround has been added to the new driver so it might not be an issue?Doesn't the TUF use the chipset for the bottom two m.2 drives too? WiFi and audio are both of no concern as I don't use them.
TUF might be worth a look but it's no prettier than the Steel Legend, imo.
Not entirely sure what the differences are (didn't look at it too closely due to the price), doesn't seem huge, but the X670E-F is ~£180 cheaper than the X670E-E, which makes it £35 more than the B650E-E.I've never had a problem with my Intel Nic either on my 650 e-e. What's the difference between 670 e-f and 670 e-e?
Because the 670 e-e was/is like £200+ more expensive than the B650 e-e this morning, but the 670 e-f is only £30 more?
It's a risk though isn't it, when you're spending ~£400 on the motherboard to hope that the network connection is OK. Maybe it can't be fixed with a software update.Not had any problems with the Intel Nic on the B650E-E, I only run it at 1Gb so have not tried it at 2.5Gb. Think a fix/workaround has been added to the new driver so it might not be an issue?
I know what you mean, my plan is if it stops working, I will get a USB-C to ethernet adapter. This is why I would prefer they did not integrate everything into boards, they use the cheapest chips they can to increase margins and we have to deal with the issues.It's a risk though isn't it, when you're spending ~£400 on the motherboard to hope that the network connection is OK. Maybe it can't be fixed with a software update.
There are things I don't like about the TUF, but at least it doesn't use that network adaptor. Same for the Steel Legend really.
On the other hand I would probably be running the network at 1Gbps, at least to start with, so it may be fine. So hard to know.
