- 6 Sep 2016
Can't find it in manual. There's probably a info button on the remote which should display audio/video codec. Does it match the original movie?
Thanks for the reply!
I only own 58X Jubilees currently, bought because they sound decent and were easy to drive by both laptop and PS5. But now I want to build a new high(ish) end desktop PC, so intend to experiment with different cans for both gaming and music. I tried a friend's Hifiman Edition XS for example, and thought they were great. So some headroom would be nice, but I don't see myself ever going too exotic.
An all in one would be nice, but I wouldn't mind a stack so long as it's not too big (I have a sit/stand desk on the way, so I'd like to keep weight and clutter down to a minimum). I've been looking at reviews for some of Schiit's stuff. The Asgard 3 with add-on DAC card looks interesting as a starting point, although it would only have a single USB input making it awkward to switch between PC and PS5. I could always add a separate DAC later if I felt the need though. Some of the Burson Audio devices looked great as well, but they're near impossible to buy here in Ireland so I've mainly dismissed them.
I also have those headphones, Very simple to drive really. I think the XS should be fairly easy to drive also.
The Asgard 3 will likely drive 99% of headphones and is a great unit. I've no experience with the built in DAC though. I have an Asgard 3 with a modius DAC. The Modi & Magni stack is recommended by many but again, I've never tried it. Hifi guides forum has a dedicated section for gaming audio so may be worth sticking up a post there if you like. You would likely get some solid advice. Topping Amp/Dac's are recommended often too.
For an all in one, Perhaps the Soundblaster G6 may fit the bill.
That Schiit stack looks promising, cheers.
Yeah, I've looked at the G6 and it seems to be quite well regarded. Not sure if VSS is needed these days though? Probably all down to personal preference.
i use an Ifi Zen dac with Hifiman Sundaras on my laptop. love the sound.Anyone recommend a good amp to power the DT990 pros?
You don't mention a budget or main usage, i.e. gaming or other media. But assuming £150-200 range I think three of the more obvious suggestions are likely the iFi Zen Dac V2 (c.£170 - seems to have crept up in price), Topping DX3 Pro+ (£200) and Fiio K7 (£190). I've had the Fiio K5 Pro a few years and would recommend but I think the price difference between it and the new K7 might make it redundant.Anyone recommend a good amp to power the DT990 pros?
Finally caught up with the Sennheiser HD 560S (which is my third headphone/set purchase this year so need to dial-in).
Initial impressions are great; comfort, lack of clamp compared to the PC38X, tonality, lots of detail. Did a lot of A-B testing tonight although only tried them with one game; Horizon Zero Dawn, PS5 with 3D audio and was suitably impressed. Directional audio on that game (and with the DTS:X configuration app) is superb. So all good.
I thought they might make my TYGR 300R's redundant, or be so similar that I didn't need both. However for certain scenarios I prefer the TYGR's so I might actually hang on to those. Although I will be selling some other headphones but still means I'm own four pairs. Which is probably one or two too many. But I certainly don't want to add anymore in the near future, if I can help it. That said when it comes to gaming I feel the TYGR's, PC38X and 560S are all stunning headphones and any one is probably 'endgame' enough. I only really think paying more would be worth it for features (i.e. Maxwell's) or for better quality for music (i.e. HD6xx series, or DT 1990/900 X etc.). And none of those more expensive examples appeal enough.
