Ah ok! Because made a ticket today and they said also 48 hours.Yep. Asked for the code yesterday, got an email this morning saying that I would receive it within 48 hours and eventualy got the code later in the day.
I installed that to begin with, but then realised the date. Had to do a fresh install after that just to make sure.What about the chipset drivers from your board manufacturer ?
All up and running now. 7800x3d, Asus x670E-F, Kingston FURY Beast 2x16GB 6000MHz CL36 all working fine without issue so far.That would be great, thank you!
Welcome to the big boys club.Finally got my 7950x3D!!!!!!
(Please work this time! )
Only use the Chipset drivers from AMD men.I installed that to begin with, but then realised the date. Had to do a fresh install after that just to make sure.
https://www.asus.com/uk/motherboard...sk_download/?model2Name=TUF-GAMING-X670E-PLUS
AMD Chipset driver V4.07.13.2243 For Windows 10/11 64-bit.
Version 4.07.13.2243
52.72 MB
2022/09/20
That’s what you should see btw.![]()
Is this what you see as well?
Thanks, hopefully this CPU won't give me any endless crashes.Welcome to the big boys club.![]()
Cool, thank for letting me know. My one is running similar to yours.All up and running now. 7800x3d, Asus x670E-F, Kingston FURY Beast 2x16GB 6000MHz CL36 all working fine without issue so far.
I just ran Cinebench and the max temp is 85.4c (idle 43c), CPU fans at 1240rpm, and case fan at 1450rpm, my case is 4000d with 3 intakes, 1 top and 1 rear for exhaust. all fans are NF-A12. Temp can be a bit lower if I set the fan speed higher. I haven't got time to check the temp in games but will do that tomorrow.
I was so scared last night when the new setup stuck on the bios updating loop but cleared CMOS solved it, also during Windows installation, it took a while to find the ethernet driver which worried me that I have a bad ethernet port.
What does the highlighted bit mean?I’m also up and running. I advise everyone using asus NOT to install armoury crate. My system is running ok despite installing the optimiser. You need the asus site for the wifi and Bluetooth etc.
Has an issue with sata and m.2. Asus documentation is poor and doesn’t state you can’t use some data and m.2 together.
Anyone wanting RGB software for memory like the team group stuff look no further than g skill. Their utility colours my memory and has a low footprint.
No idea. I must have triggered something to do that via the characters I typed. I’ll edit it to see if I can remove it.What does the highlighted bit mean?
oh sata and m.2, that makes some senseNo idea. I must have triggered something to do that via the characters I typed. I’ll edit it to see if I can remove it.
Interesting. At least they state which sata ports are disabled when you connect a specific m.2. No such look with my X670E-A manual.Just found this bios manual for the ASUS TUF Gaming x670E motherboard. Quite handy.
https://www.asus.com/uk/motherboard...desk_manual/?model2Name=TUF-GAMING-X670E-PLUS
Some 7800x3D issue within the socket, burned the pins?, not common, but lets hope its a one off.Reddit - Dive into anything
www.reddit.com
