If it is proper grim stuff I would lay kitchen roll over it and soak it in Windex and let is rest for a bit.
Agreed. That's horrific and needs spoiler tagsNew car time![]()
He was like meh, brushed it off with his bare hand..Agreed. That's horrific and needs spoiler tags![]()
Best Tar spot remover please?
I bought Gtechniq W7 Tar and Glue Remover but not finding its very good at shifting Tar spots at all!! Anything else I should get instead please anyone??
According to the instructions though your supposed to spray on a cloth not directly onto the paintwork! You seeing any issues around your method with any damage at all yet?Really? I used it last night for just that.
Found it does the job well - spray on, pressure wash off.
My paintwork is dry its just not working for me at all! Think I need another product which works differently.Nope, but I spray localised and with the micro fibre underneath so that it doesn’t drip.
And of course I don’t do it regularly
Edit: reason I do it this way is that tar remover works best when paint is dry, but you don’t want to be wiping a micro fibre on dirty paint
Yes, I didn't report it to modsWhat --- you are joking
Just finished a 2 stage polish and CQUK application.
Anyone got any recommendations for a spray on sealant/tooper/detail spray to use periodically to boost the finish? I see SiRamik Lustrous Plus seems to be sweetheart of spray sealants at the moment - but out of stock everywhere at the moment. Anything else worth a go?
Just a top up?
I think carpro do something like that, not sure
and![]()
CarPro Reset - Intensive Car Shampoo
CarPro Reset Intensive Car Shampoo CarPro Reset Shampoo is a car shampoo designed specifically to maintain Ceramic Sealants, such as CarPro CQuartz UK 3.0 by removing the dirt whilst not effecting the coating itself. CarPro Reset was formulated specifically for nano-technology based sealants andwww.cleanyourcar.co.uk
CarPro - Reload 2.0 Spray Sealant
CarPro Reload Spray Sealant The fastest and most effective spray sealant, spray on and wipe off! Carpro Reload is a water-based product mainly composed from special modified silicon polymers (not silicone), glass based coating. Carpo Reload 2.0 will leave a temporary layer and shield of prowww.cleanyourcar.co.uk
Liquid Crystal from Gtechniq would be my number one choice.
