Yeah, got it today. Just make a ticket for it.Are you guys getting game codes for 3D CPUs.?
I picked this board because it has the best VRM of the b650 m-ATX boards. They all have some negatives, the Gigabyte has the least of them.I've seen this board come up a couple of times now. I haven't seen anything negative about it and it even comes in at around £210, which is very reasonable.
What made you pick this one in particular?
I'm getting closer and closer! Although finding the G.Skill Neo 6000 CL30 in stock anywhere is proving a challenge. I may have to swap it for some Corsair Vengeance RGB stuff (which seems to come in a little cheaper too).
Not really fussed about RGB but I can stomach the RAM and GPU having some lights I guess.
What game and how to claim one.? I bought 7800X3D April 13th.Yeah, got it today. Just make a ticket for it.
All I did was enable PBO, go to Curve, set it to negative and put in 20. I'm actually running -25 now but it's solid. Running EXPO II for RAM.what's the idiot's guide to enabling PBO? i have a X670E Hero and a 7950X3D, and tbh i was done years ago with proper manual overclocking, cba with all the stability stress testing, and then having it fluff its lines randomly when idle. on this old 8700k i pretty much left it stock, XMP is on and it's set to boost all cores to 4.7, and i dialled down the LLC to 4. what are the similar "can't go wrong" settings on AM5? i have EXPO ram so i guess i will set that, is it then just PBO Auto and CO (whatever that is) Auto?
Edit: No that’s wrong I ordered it on the 6th of April and it was delivered on the 12th.
Ok I know what game now and sent a ticket although I'm not sure if my order qualifies as the offer wasn't showing on the website back then.
and what does 'auto' do?All I did was enable PBO, go to Curve, set it to negative and put in 20. I'm actually running -25 now but it's solid. Running EXPO II for RAM.
Yea that is bad although updated bios mostly solved the problem. Wonder how other A620 boards will do.From hub: a620 is trash, do not buy
You can get the non RGB on the American rain forrest site for $139 plus shipping.I'm getting closer and closer! Although finding the G.Skill Neo 6000 CL30 in stock anywhere is proving a challenge. I may have to swap it for some Corsair Vengeance RGB stuff (which seems to come in a little cheaper too).
Which setting set to auto? PBO? Nothing I would imagineand what does 'auto' do?
Was about to buy a 7800x3d but stumbled on the framechasers review where he states games have bad 1% lows causing stutter, He calls it a amdip.
Anyone had this on their cpu?
Hi, I'm getting the same board tomorrow hopefully. Did you have to change any settings to get EXPO working with the new 1409 BIOS? There was talk on Reddit about enabling Memory Context Restore in 2 places in the BIOS first, did you have to do this as well?Pleased to report that with the 1409 bios on the ASUS X670E TUF Gaming Plus I am able to enable EXPO II at long last with my Corsair Dominator Platinum RGB DDR5 6000 cl30 expo memory.
Yup.Hi, I'm getting the same board tomorrow hopefully. Did you have to change any settings to get EXPO working with the new 1409 BIOS? There was talk on Reddit about enabling Memory Context Restore in 2 places in the BIOS first, did you have to do this as well?
You redeem it on amdrewards.com, and it will become available when the game is released on the 28 April 2023.Just got my AMD Rewards for Jedi Survivor, I assume since its pre release i'll get the actual game key on release? or has anyone got it early
I'm close to pulling the trigger on the following unless anyone can suggest improvements:Keeping an eye on your build I want the same case, can you let us know how you get on.
I’ve been following your improved timings for various RAM. Based on what you have recommended for others I think I could tweak mine a bit. Currently it’s running EXPO II.New learnings, so slightly different timings than I've previously suggested.
This is based on running 6000C28Mhz.
- Dram VDD 1.45v (you might be able to lower this if the below is stable)
- DRAM VDDQ 1.35v (always keep 100mv lower than VDD)
- SOC is fine, but can try to lower to 1.25v-1.3v later
- VDDP is fine, but can try to lower to 1.100v-1.125v later
- Memory Context Restore and Power Down Mode Disabled - tolerate a ten second longer post time
- If you won't disable Memory Context Restore, you need to leave power down mode enabled (these two features are mutually exclusive atm) and put up with the little latency penalty for doing so
Possible further improvements would be as follows:
If that's okay, further improvements could be:
- RDDL 12
- WTRL 24
- RDRDSCL 5
- TWRWRSCL 17
RDC 34 (not sure if this would be stable would need testing depends on DIMM quality)
TRP 34 (not sure if this would be stable would need testing depends on DIMM quality)
RAS 46
RC 80
RFC 472
RFC2 256
