Ok that's what I thought, so because EXPO/XMP profile is disabled, even though I am running higher MHz and tighter timing the SoC voltage should still be at default (though worth double checking)Nah, the RAM voltage is unrelated, that's the voltage which is supplied to the RAM sticks. If that was an issue it would be the RAM being fried not the CPU/socket. The SoC basically contains the memory controller of the CPU among other things, which is why the SoC voltage also gets raised when you set EXPO/XMP, as the memory controller will also be stressed more when running ram at higher speeds/tighter timings.
I think im going to try 1.25 like rawr has when i get home, see what happensI'm not sure if I should stick with default values now until all this blows over?
I'm at 1.2v and it's working just fine (no crashes or issues)I think im going to try 1.25 like rawr has when i get home, see what happens
There is another Reddit user with a blown 7800x3d, says he built the pc and it went to bios fine but as soon as he tried to boot windows the 7800x3d went Pop!
So changing the motherboard to an MSI one won't actually fix the issue then. That's good to know. I wonder if the memory timings error is related to this in some way? I have no idea.To be honest MSI is the only manufacuturer I haven't personally seen a burn out from, but I was watching buildzoid and he said he had so i'm erring on the side of caution really. Rather do that and end up with a burnt cpu, lol.
MSI put out a notice the other day that their latest bios addresses this issue but it seems they might have thought it was a different cause? They specifically mentioned blocking being able to do positive offsets so that's probably why the SoC currently remains at 1.35v with EXPO on.
Makes you wonder what the real story is, hopefully we'll see something more full from Steve @ GN.
Thanks for posting this btw.This was just posted on the ASUS PC DIY FB group .
(Unofficial) ASUS PCDIY Group | Facebook
The Official ASUS PCDIY Group has moved to the Heartbeat Platform, which is currently a private group. For ASUS fans located in the US and CA rejoin,...www.facebook.com
Community Notice - ASUS AM5 motherboard owners
An important update for Ryzen7000X3D processor owners
Several AMD Ryzen 7000X3D owners have reported CPU and motherboard failures. We acknowledge the incidents/issues and have been communicating with AMD to analyze the possible causes. We have also contacted affected users to provide support and collect additional information.
Ryzen 7000X3D processors do not allow for CPU ratio or CPU core voltage tuning (CPU overclocking) but do allow for performance tuning and DRAM overclocking via PBO2 and EXPO memory. To support EXPO and/or memory overclocking at DDR5-6000 and beyond, SoC voltage has to be sufficiently increased to ensure compatibility and stability. The amount of voltage required varies between CPU samples. Some processors are more sensitive to overvoltage than others, and some are capable at running higher memory frequencies without needing as much voltage.
As confirmed with AMD, any intentional manipulation of these settings can damage the processor, socket, and motherboard. To mitigate this, we have been working with AMD to define new rules for EXPO memory and SoC voltage. To help protect the CPU and motherboard, we are issuing new EFI updates to limit the maximum available SoC voltage to 1.3V.
We recommend updating your motherboard UEFI BIOS to the latest release. Please also ensure the CPU is cooled adequately. Our recommendation is to use at least a 240mm AIO liquid cooler or high-performance air cooler.
If you have been affected, please do not hesitate to contact ASUS support for your region.
Any additional updates will be noted and updated in this post.
FAQ -
1. When are the new UEFI releases going to be released. Our expectation is to have the UEFI BIOS updates posted and available through the service and support website within the next 24 hours.
Good spot. It's not on the UK ASUS website yet. I really don't know dude. I think I'll wait for the non-Beta.Just noticed a TUF beta bios 1412 on the asus page that specifically mentions a SoC 1.3 cap, are beta's worth the risk you reckon? Or just stick latest release and manually lower the SoC?
Just updated mine and it seem good to go. As a side note, anyone know when the codes for Jedi Survivor are coming out?Good spot. It's not on the UK ASUS website yet. I really don't know dude. I think I'll wait for the non-Beta.
They are already being issued dude. Just email OCUK customer support and they normally get back to you within 48hrs.Just updated mine and it seem good to go. As a side note, anyone know when the codes for Jedi Survivor are coming out?
Yeah, I mean from AMD. Have you had yours yet?They are already being issued dude. Just email OCUK customer support and they normally get back to you within 48hrs.
"Congratulations on reserving STAR WARS Jedi: Survivor™! We will update your account and notify you as soon as the content key is available.Yeah, I mean from AMD. Have you had yours yet?
Same here mate. Thanks for confirming! Much appreciated!"Congratulations on reserving STAR WARS Jedi: Survivor™! We will update your account and notify you as soon as the content key is available.
Release Date: 2023-04-28
The release date is determined by the publisher and may change without notice."
That's all I got.
You reckon 1412 is good to go then?Just updated mine and it seem good to go. As a side note, anyone know when the codes for Jedi Survivor are coming out?
Seems good to me.You reckon 1412 is good to go then?
Only one way to find out.Seems good to me.
