Permabanned
- 9 Aug 2008
I wish you had got a job in tech so.
Oh so you work in tech? Are you a network engineer?
They can just use another one. You won’t stop the kid.
If you'd been paying attention. You'd have read he has another laptop. But it's slow ultrabook. It will like trying to cut the lawn with scissors.
I thought you wanted to replace it with a slower laptop?
Maybe he’s got a key logger on it.
Maybe he’s got some software tools to bypass your admin passwords.
Maybe he’s got a secret webcam set up watching you type a password.
Maybe he’s got a logger cable between keyboard and port.
Maybe you should just ask them.
But it's been entertaining thread on a slow day.
Maybe they hacking you via Bluetooth?
Have you considered using ChatGPT.
The circus wouldn't take him.You defo haven’t. I don’t need to, this isn’t a problem I have got to resolve but you can resolve it very easy.
No bitlocker will not help to stop him because he will find plenty of ways to bypass bitlocker password or disable bitlocker at startup with iSunshare BitLocker Genius.Put a bitlocker startup password on it. That’ll stop him![]()
4 Ways to Remove or Disable BitLocker Drive Encryption on Windows 10
www.isunshare.com
www.isunshare.com
mspoweruser.com
Remove Password in Windows 10: Bypass Login Easily
Discover easy methods to bypass Windows 10 login when you forget the password. Learn how to login to Windows 10 without password.mspoweruser.com
Or boot from another device like a usb
Yes he can bypass this with bootable USB Windows PE or Live11 reset bitlocker pin and password too.
