The issue is mobo vendors making enabling EXPO raise the SOC voltage to help stability.
Things need to be put into some sort of perspective.
Gamers Nexus, by their own admission had to force and actively try to trigger the failure and it took a lot of effort even though they new what to look for.
We have had possibly 10 failures from Reddit, OcUK alone sold/pre-sold 500 units in April ( approx figures from Gibbo ) - so if the entire Reddit community worldwide bought them from Overclockers - thats a failure rate of 2%.
I'm not saying this situation is acceptable, but you can estimate the likelyhood of it happening are pretty slim.
All hardware has a failure rate.
(I'm currently building a 7800X3D and Asus B650E-E pc at the moment, we'll see if this post has jinxed me)
Not impossible for the sun's radiation to flip a bit in the BIOS while in transit....No. Unless you return a board for RMA and its enabled.
I would imagine that a change like this would be legally problematic. Motherboard manufacturers advertise EXPO as a feature and detail validated ram kits.How on earth can EXPO, a memory profile created by AMD, that HAS to be turned on in order to reach the memory speeds of the RAM you bought, cause the warranty to be void ?
It's crazy.
Thanks. That makes sense. I have turned EXPO off for now. I don’t need the extra performance.No. Unless you return a board for RMA and it’s enabled.
Could probably just flash the bios again. The computer doesn’t need to be on or even have a CPU to do that. It would put everything back to default.No. Unless you return a board for RMA and its enabled.
I'd recommend all Ryzen 7000 owners to inspect their CPU's contact pads and motherboard socket pins, check this video to see the angle/lightning you need to spot the visible burn marks (will likely be much less noticeable if your CPU is damaged but still working)GM failure lab claims there is a "unknown amount of damage to the cpus out there in the field already" (degradation) and they are working on a new video.
GN also mentioned in their latest vid that it's quite possible that chips have been running "fine" but will have suffered some degredation due to the issue, so it may have just shortened the lifespan of the chip where it won't fail tomorrow, but is more likely to fail in the futureGamers Nexus, by their own admission had to force and actively try to trigger the failure and it took a lot of effort even though they new what to look for.
The issue is someone not putting a voltage limiter on the CPU, chipset, or motherboard to prevent damage.
failure is one thing and degradation is anotherThe MTBF of silicon chips is pretty well understood. We have tons of papers on the effects of voltage and electro migration.
Video summary. More voltage = more bad. For longevity run your electronics at the lowest possible voltage and as close room temperature as possible. Power down when not in use.
And if there’s burn marks, what then?
Send CPU back to Overclockers for refund or replacement?
Just hit the bios reset button on the back of the board......if it doesn't have one, use the jumper, default settings.....here I come.Could probably just flash the bios again. The computer doesn’t need to be on or even have a CPU to do that. It would put everything back to default.
it doesn't take that much to degrade a chip to a point where it doesn't boost as high or becomes unstable with the same voltage as before and needing more.
Steve even talks about it in that pcworld podcast he was on the other day. How you would have needed to have limit tested when you first got the CPU to see how far it would push to then figure out if/how much the cpu would have degraded by now.Degradation starts as soon as the CPU is power on, maybe even as the chip leaves the production line.
Properly explaining silicon degradation is beyond the scope of a YouTube video. Steve isn’t going to be able to put a number on this question for you.
