Getting the Windows 11 look in 10….
Caporegime
25 Nov 2004
On the road....
Having recently seen a friend’s new Win 11 built PC, I liked the look of the U.I. over 10, which has made me wonder if I should give 11 a go.
But, fundamentally my current 10 install runs well, my 4790K isn’t supported (although I read I can by pass certain checks and install it anyway if I really want to) but, my obvious solution is to just make 10 look like 11 via something along the lines of a “Start is back” type of thing.
So, is this a thing and if so what’s the goto method?
Or, do I just throw the security concerns to the wind and go ahead and install 11 anyway on my 4790K system?
I would go with the upgrade, see my post here from earlier in the day on how to bypass the hardware requirements.
Having upgraded to an ultrawide monitor around the same time I upgraded to Windows 11, the central position of the taskbar icons is the the most useful feature.
PM me if you need an ISO
I'd say if you want Windows 11 just install it rather than trying to fake it somehow.
Use this tool to check the other system requirements of Windows 11 as there's more to it than just CPU:
My opinion is it's not worth installing Windows 11 on an unsupported system unless you plan on still using that system in 2025 when Windows 10 support ends. Most people won't want Windows 11 until it has the ability to never combine taskbar items, which is expected later this year.
I’ll drop you a PM later today, I’m certainly interested. :)
I’ve previously checked and my 4790K isn’t supported, a lack of TPM 2.0 being the main issue I think, I’ve looked into getting a 2.0 TPM module for my ASUS Z97 Pro Wi-Fi board as it has a socket for it but as I understand it without the relevant BIOS update to support it which I don’t think ASUS have released then there’s no point in having it.
Ultimately there’s nothing on my system that’s the end of days we’re I to lose it so I may just be done with the security concerns and try it anyway!
Might be worth posting your WhyNotWin11 results here for a sense check. I had some involvement in that project so know the requirements and workarounds pretty well.
Apologies for the crap picture quality - literally took a photo of my screen with my phone :0
Basically its saying the CPU (i7 4790K) isn't supported nor do I have TPM.
Just checked on Reddit and users have installed W11 on CPUs older than yours and running with no issues.
I've sent you a link to the ISO.
Recieved, and thank you, I'm creating the bootable USB now, sod it! lets see what happens! :D
Appreciate your help Sir. :)
Yep looks like that's the case. That's unusual as most ppl who fail on those things fail on others too, but it's a good thing.
Sounds like you're already on your way, but there are a few different ways to do the install, here's a link with the info:
@Scania how did it go?
Sorry for the late reply,
So far so good, the installation was seamless with your ISO (thanks again!) I’m liking the U.I. (Although I have Startisback and have installed it to 11) it just feels more up to date than 10 and has a lot of subtleties which I’m liking - so far - feels relatively snappy and responsive although that’s usual for any clean OS install tbh.
I’m noticing clicking on a folder of MP3’s for example takes a while to open for some reason, I’m yet to try any games or indeed see if my SLI 1080ti’s are still available as such.
But, for general usage so far, I have to say I quite like 11, time of course will tell! :)
Unsure if its been mentioned but I use Explorer Patcher which gives me the combine options back, quick launch and the Windows 10 start menu and on top of that its free
I hate having to click again for the show more options right click menu to copy/paste/delete/rename etc etc :mad: :mad: :mad:
I just noticed there now small icons for this at the top of the right click menu....... how long have these icons been there :confused:
I hate this too, the icons for copy\paste etc have always been there in Windows 11.
I use the more options a lot on client PCs and its annoying having to click it each time. On my work laptop and desktop I have the classic 1s set which is done through patch explorer.
