Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
errrr, yes?
Is it difficult to install? I gues you just got to be careful swapping them out right?
errrr, yes?
its quite easy, there's a screw holding a bit of plastic over the posts of the buttons. You take that off and they fall out - it's then just a case of hookign them back in.
The ones above were a test pint from the resin printer (finally) and I'm just working out the best orientation to print them (the posts failed on all but 1) and then will print off some extra for you.
Oh neat and fantastic. I would love a set, could you let me know how much for your trouble? Just drop me a PM when you are happy with them but I am suer it's better than the stock ones.
You are a gent, just let me know and I'll pop some coin over to you.it'll be just the cost of postage mate - they cost 40p to make
@montymint that's awesome! I'm after some buttons too but don't like the idea of breaking the clips, they they easy enough to fit? How much if you could print and ship 8 more buttons? (I have 2 RG35XXs) I'm in UK, Leeds.
Anytime is good with me - drop me a PM and ill send postage money and what they cost in materialsjust postage again.
Just FYI I'm still tuning the resin printer up after being in storage over a year (and it's acting up) - so probably won't be in a position to post until the end of the week
Very nice! I 100% agree with your comments, motion on a CRT, there is just something that a flat panel cannot replicate - Doom, Ultima games look glorious on a CRT!I regrettably sold my 19" CTX Diamondtron monitor last near in the midst of a House move and have regretted it ever since. I've been on the look out for a replacement since then and this popped up locally and decided to grab it. It's a 19" Mitsubishi Diamond Plus 91 CRT. There is some smearing on the Anti-Glare Coating which I plan to some way sort out, but the case is not yellowed and it great condition. Colours and Geom are also spot on. Picture is great. CRT's in motion just look better then LCD's, even at the same Refresh Rate. Happy to have a nice quality CRT back for my retro PC.
How will you rectify the anti-glare coating?
I have a similar issue with an iiyama Vision Master Pro 453.
I'm going to first just try removing the coating. I've read Autosol can get rid of the coating and also an abrasive cleaner like Flash with limescale remover can remove the smeared coat. The trade off with removing the coating, is the screen becomes a lot brighter and can in some circumstances be hard to use in well lit rooms. If after removing the coating and finding the screen is overly bright or is hard to use, I'm going to remove the film entirely and replace it with a tint film that is used for cars.
I found a Video on youtube replacing the film on a JVC PVM monitor with good success.
I guess for you, it would be a case of finding the Service manual for the 453 to find out how to remove the case plastics to get the film off the tube.
I'll document my progress on the monitor as I try each method. Ideally I want to get rid of the smeared coating as the screen is great!
