Ok I will do that now.Check that the SOC is below 1.3 and enjoy it.
If its not, then make sure you have the newest BIOS installedOk I will do that now.
That's my plan, install the latest one before even dropping in a CPU.If its not, then make sure you have the newest BIOS installed
Lol well that is the one that limits the SOC voltage. AS GN says you can't offer a fix, and then say you can't use it as it voids your warranty, to then leave you with a non-beta BIOS that kills your hardwareJust not the beta bios as it may not have any warranty if you do that lol.
Something's changed then as they have the most expensive B650E listed on overclockers and the most expensive B650 too, by a margin in both cases. Their X670E boards start at just £500...When I was looking at B650 motherboards Gigabyte seemed competitive on price, but they have a lot of reports of coil whine on the VRM which would put me off them.
Even the Gigabyte and ASRock issues?TLR , this is all literally Asus doing this with shoddy boards and shoddy customer service
Yeah, I'm having the exact same issue. I've got a Asus Strix X670E-F and can't find anything comparable in that sort of price range.I do think i should try to get this board swapped ( not purhcased at OC ). But looking at other x670e boards they cost way more.
I notice on the bios for one of the MSI board, don't remember which Carbon I think (not sure if B650 or X670) I think it says that the new 1.3v limit might cause some compatibility issues with some memory kits.Ok I checked the SOC voltage and its at 1.296V with the latest 1410 bios, now does this mean I cant use EXPO? Sorry but as with the price I apid for this board, Im panicing a bit here.
Ive been using an ASUS X670e Gene for months, and I love it, never had a problem with it, its the only X670E board that I liked that came fully loaded with PCI-e 5 and USB 4.Something's changed then as they have the most expensive B650E listed on overclockers and the most expensive B650 too, by a margin in both cases. Their X670E boards start at just £500...
That is funny
Someone is about to get a new ass hole.Love to be a fly on the wall in their boardroom![]()
The BIOS has put a 1.30 maximum in place, you are fine.Ok I checked the SOC voltage and its at 1.296V with the latest 1410 bios, now does this mean I cant use EXPO? Sorry but as with the price I apid for this board, Im panicing a bit here.
For what it's worth I think they're just covering their arse just in case. I don't think Ram will be too affected on any board by the limit unless you're wanting to really push it to the limit. Ryzen is pretty bad any way at pushing Ram to it's limits regardless of SoC though.I notice on the bios for one of the MSI board, don't remember which Carbon I think (not sure if B650 or X670) I think it says that the new 1.3v limit might cause some compatibility issues with some memory kits.
And MSI apparently don't have any issues with high SoC voltages but the 1.3v limit has apparently still impacted them.
Ok thanks for that answer, I think Asus will bring a final bios to sort this out and hopefully soon.The BIOS has put a 1.30 maximum in place, you are fine.
No reason why you cant enable EXPO, mines enabled and SOC 1.24 ( Auto set that ).
It will vary slightly depending on memory,board, chip.
According to the video even with the limit in place the Asus board tested was still using 1.33v when set to 1.29v in the BIOS.The BIOS has put a 1.30 maximum in place, you are fine.
Tsmc will have it, amd im not so sureI think you would find that the testing and inspection equipment at the manufacturer would be far superior! At least you would hope so.
indeed, which is why everyone is blaming Asus (and other brands) for it being too high. Asus boards are even ignoring the 1.3v limit, that's how much control the motherboard has.As the video said, vsoc is 100% controlled by the motherboard
