Yup.I have WireGuard on MBA and iPhone and I have it configured so that it connects when I'm on cellular or when I'm connected to any WiFi other than my own. Is there a similar option on the macOS version as well?
	Super Agent for Safari now wants payment, any decent alternates? It works alright, but not well enough for me to pay what they want for it.
	I've found two mentioned elsewhere as alternatives, Consent-o-matic and Hush. I'm giving the former a try now.I'll ask in a work Slack channel tomorrow what's decent.
I've decided to learn emacs. I do quite a bit of work with Linux VPS instances and figured it would be a useful skill to learn. Wish me luck!![]()
 love a vim user.Yup, seems to be good for me on both iPhone and Mac. if anything, it's better than SuperAgent because I think it just hides cookie messages, I'm not seeing anything at all.Trying Hush on my Mac, seems fine so far.
Yeah, it's very good. And free!Yup, seems to be good for me on both iPhone and Mac. if anything, it's better than SuperAgent because I think it just hides cookie messages, I'm not seeing anything at all.
I used Tunnelblick before I moved my VPN over to Wireguard.Can anyone here recommend a decent VPN utility app that supports (L2TP/IPSEC) VPN reconnection?
I've tried a few off the app store but i've yet to find one that actually works well, if at all, and Draytek's own app doesn't support L2TP/IPSEC under MacOS (we would have to rollout SSL VPN).
I'm after something that's a bit more user-friendly that rolling with a script to end-users/staff.
Exactly what I did.I used Tunnelblick before I moved my VPN over to Wireguard.
OpenVPN client? Or does it support other connections?I used Tunnelblick before I moved my VPN over to Wireguard.
Check the documentation:OpenVPN client? Or does it support other connections?
Literally just after something that will reconnect a VPN profile when it disconnects as some remote users here have flaky internet connections and moan their VPN 'goes down' and Apple have yet to/or won't implement reconnect (most other OS's have supported that feature for yonks).
