I've recently bought the Autobrite short trigger gun to use with my Karcher K7 which came with the snowfoam connector but as you can see my old AutoBrite snowfoam lance has the karcher connector on it.
Is there anyway to remove the karcher connector so i can use the supplied connector to be able to use it with the Autobrite short gun (or do i need to buy the snow foam lance again)?
If this is an impossible task then can someone please recommend any better foam lance's which may be worth considering along with a new AutoBrite one (as its never in stock now anyway).
