@Participant are you in the SAS or a Spy?
Be a terrible Spy if he told you!
), and the most useful machine I have lives again. An equivalent new one is near £4000. I can fill diving bottles to run air tools remote from an air line, blow up tyres and start engines with air starters again. having compressed air in carry-able bottles is just SO useful. Plus i can charge people to blow up their bottles for air guns... 207 bar in the small bottle in the photo, a full size one in the truck lasts for months given modest usage.
Can't beat a trimmed front bush imo.Trimmed my front bush.
There's so much bush I had to borrow 3 of my neighbours green bins.
Its a bit stubbly at the moment. But give it a week or too and that nice soft layer on top will form. It was so wild before it brushed the postmans package when he droped something off round the back door. (it's my safe space)Can't beat a trimmed front bush imo.
Did you leave your back door open for the postmanIts a bit stubbly at the moment. But give it a week or too and that nice soft layer on top will form. It was so wild before it brushed the postmans package when he droped something off round the back door. (it's my safe space)
. Can't beat trimmed push innuendos.I initially assumed the top photo was the end result, not something you tore apartSpent the last few days turning this (forgot to take before photo so pinched this from rightmove)
Into this
Next job, take up all the floorboards, mainly because they creak so badly, but also to allow plumber access to move pipework.
I don't think I can actually explain if you can't see just from looking at the photoI initially assumed the top photo was the end result, not something you tore apart
What was up with the original, looked fine to me. But bathrooms to me are just places to show how much money I've just wasted on beer![]()
Looks pretty dated the original imo. The tiles are horrendous and not sure I could stomach that off white bath panelI initially assumed the top photo was the end result, not something you tore apart
Have you put yourself a tap on bottom or is it already there ? I have also put overflow pipes on mine - There is a big hole behind my fence in field as the overflow is boring it's way into the ground.Fitted the gutter / water butt kit to the greenhouse
Removed the token gutter ends which came with the greenhouse
Fitted (pushed in) the more substantial ones from the kit to the door end
Fitted the end / downpipe connector to the "back" end
Drilled a hole in the closest side of the water butt
Cut a short length of downpipe, out fitted to the gutter end and push fitted the water butt hose in the other
Screwed the fitting into the hole in the water butt, connected the pipe and clipped into place
The other side is also done awaiting another water butt or second connector pipe into this one
I have also put a male hose fitting on top of butt so if you run it dry you can fill it up with no problem.
Gutters on our greenhouse are rubbish - we been here 13 yrs and it was already here. Bodged them a bit here and there.
Still filled butts with those heavy rains we had the other night.
