- 21 Jul 2005
- Officially least sunny location -Ronskistats
But not all games support dlss..just under 300 I think support dlss2.
I'm sorry but unless the native AA implementation is total crap native > upscaling.So if you target 1% low fps at 30 while using dlss youll get much better image quality. Dlaa is kinda pointless when dldsr + dlss does the same thing but better, and it doesn't need specific support, it just works with everything.
I think you just don't understand what im saying....I'm sorry but unless the native AA implementation is total crap native > upscaling.
Again, I'm on 1080p, the worst resolution to use any kind of upscaling tool so I'm not the target for those tools.
If any brand wants my money, I'd rather have HDR emulation than upscaling. If DLSS works for you more power to you but I want the full fat supersampling, not the emulation.
And rendering at 1440p natively then downscaling gives even better quality, simple as that.I think you just don't understand what im saying....
Try to read it slowly this time. If you target a specific framerate, using DLSS to get there will undoubtedly give you better image quality. You said you play at 1080p. Good, rendering at 1440p natively and then using DLSS on top will get you better image quality than native 1080p. Simple as that
BUT LOWER FRAMERATE!!!???!?!And rendering at 1440p natively then downscaling gives even better quality, simple as that.
Man, if I can't get the 1% low at 30@1080p/1440p on a 3+ years old game it's time to get a new card rather than upscale.BUT LOWER FRAMERATE!!!???!?!
So to match that framerate you can render at 4k and use DLSS Q which will be better than native 1440p...
This has absolutely nothing to do with how tolerant you are to low framerates. No matter what framerate you want to play at DLSS will get you that framerate with better image quality.Man, if I can't get the 1% low at 30@1080p/1440p on a 3+ years old game it's time to get a new card rather than upscale.
Can we just agree to disagree? I played Doom 2 @15fps in the 1990s, it's very likely that I am much more tolerant than you to low framerates and we're looking at different things in the way we enjoy games.
Look Bencher, no upscaling tech will ever be as good as supersampling so please stop preaching the DLSS gospel at me.This has absolutely nothing to do with how tolerant you are to low framerates. No matter what framerate you want to play at DLSS will get you that framerate with better image quality.
Im not preaching anything, just stating facts. 1440p + DLSS Q looks better than native 1080p with comparable performance. 4k DLDSR + DLSS Q looks better than supersampled native 1440p with comparable performance. DLSS just gives you better image quality when you are trying to match framerates. Apparently you don't like that fact, but what do you want me to do about it, pretend it's not true?Look Bencher, no upscaling tech will ever be as good as supersampling so please stop preaching the DLSS gospel at me.
Set it to maximum and if it's any lower it'll be a nice surpriseI'm trying to calibrate my disappointment now!
Do we have any idea of release timeframes in the next two years? I'm trying to calibrate my disappointment now!
That's basically DLAA though.I mean it's very straightforward, 1440 + DLSS Q looks much better than native 1080p while it offers very very similar framerates. That much cannot be argued with. Therefore supersampling native will not help you, cause you can supersample while using DLSS Q as well. Whoever argues the above is doing it on bad faith.
Not really, DLDSR is much better than DLAA cause it uses higher quality LODs, since you are basically running the game at higher resolution. That's why I've said multiple times that native is "dead", in the sense that there is no reason to run any game in native resolution anymore. If it's framerate you are after enabling DLSS is basically a no brainer, if it's image quality you are after you go the supersample + DLSS way. No point in native anymoreThat's basically DLAA though.
Holy crap, the difference in TLOU is huge.DLAA isn't anywhere as good as DLDSR + DLSS, DLAA is just purely AA, basically dlss without the upscaling. This is native vs DLDSR & dlss:
And one from mrk:
I can see why the distortion might look better in some ways but I can also see several spots of oversharpening. If those are noticeable on my 1080p monitor I shudder to think on higher res...DLAA isn't anywhere as good as DLDSR + DLSS, DLAA is just purely AA, basically dlss without the upscaling. This is native vs DLDSR & dlss:
And one from mrk:
