- 20 Oct 2002
- Oxfordshire / Bucks
Feel your pain, my wife’s car has a few dodgy spots from when bird poo etched the paint and one spot where it ate through the clear coat then the paint.Bird poo strikes again. With the weather it burnt-in in record time.
To be honest this is how I got into detailing, after learning the hard way what bird poo will do to a car without any protection. I now remove any bird poo as quickly as possible. I swear my neighbours think I am mad cleaning our cars as regularly as I do. In hindsight a air riffle way have been cheaper.
Does your car have any protection on it?
A bird absolutely demolished my car yesterday. Don't know what bird it was but pretty much covered half of my bonnet and down the side too. By the time I got home it was already cooked into the paint. Used the Maguire's no water wash and wax to get it off. Seemed to do a good job!Bird poo strikes again. With the weather it burnt-in in record time.
BSD is still better than nothing.Pain indeed. Just Sonax BSD.
I'm okay with it as its a daily, and everyday is a lottery of what damage it'll attain next.
Sat there trying to blast off a bit of mud with a pump sprayer, absolutely mind numbing. Better off just hosing it down at a petrol station car wash and then doing the rinseless stuff.
@Mekrel
Hi mate, what battery is in your greenworks and does it last long enough ?
Anyone else got a greenworks 40V cordless washer ?
He's not blasting it off, the ik sprayer isn't powerful, the chemicals are disoving themSat there trying to blast off a bit of mud with a pump sprayer, absolutely mind numbing. Better off just hosing it down at a petrol station car wash and then doing the rinseless stuff.
I have three batteries, but only really tend to use two for a proper clean which requires a lot of rinsing. Two are the 4ah official batteries, another a third party 5ah battery off eBay that definitely doesn't last as long as the official battery despite claiming a higher capacity.
The proper clean has a lot of use of the PW because there's rinsing the wheels after pre-wash, rinsing them and arches after the contact wash, applying snow foam via lance, rinsing, contact wash on bodywork, rinse. Might the occasional additional rinse if using chemical decontamination products.
I don't think I've ever used more than the two batteries, I have three because the 3rd party one was initially temperamental and Greenworks had a black Friday sale on their direct to consumer website.
If the poop has etched into the clearcoat then applying heat is the way to resolve it. There is lots of talk of acid in the poop etching the paint, this isn't really the case. What is happening is the clearcoat is heating unevenly due to the stuck on present from the feathered friend. Waxes can help a bit but mainly from the point of view that the poop is floating on the wax. It isn't guaranteed to stop clearcoat marks by any means.Pain indeed. Just Sonax BSD.
