How much performance do you gain?Exactly the opposite for gaming!![]()
For some reason SMT works different to HT. I'm not sure why but AMD CPU's on the whole are better with SMT on when gaming.Yeap, HT off ecores on is the best for gaming. You can't do that on the 3d cause it will choke on just 8 cores without HT. That's why im eagerly waiting for a single ccd 12core 3d zen. That's going to be nutty.
I'd imagine the 7800x 3d will run better with SMT on than off cause it lacks physical cores. The same way eg an i7 7700k was faster than an i5 7600k. I don't think a 7950x would be better with HT on though, not for gamesFor some reason SMT works different to HT. I'm not sure why but AMD CPU's on the whole are better with SMT on when gaming.
13700k compiling shaders for 20 mins already cost you 5 quid in electric, pc gaming at this rate only going to work for me if i swap my glasses out for a monocle.But that's not a ycruncher workload lol. I told you already, 12900k was peaking at 150w during shader compilation in tlou
Framechaser? The guy that they adore in the WCCFtech comment section. That says enough.Why didn't they test the 13700k with ddr5-8200 RAM? Framechasers says it's the RAM Intel gamers use
Apparently Intel CPUs are getting low FPS in the new Warzone Season 4 map Vondel. I wonder if framechasers will cover it? #IntelDipWhy didn't they test the 13700k with ddr5-8200 RAM? Framechasers says it's the RAM Intel gamers use
Finally, one map where intels lose in lows?Apparently Intel CPUs are getting low FPS in the new Warzone Season 4 map Vondel. I wonder if framechasers will cover it? #IntelDip![]()
You know it.Finally, one map where intels lose in lows?
Im go if you wanna test
Which card you using? 4090 gets creamed without dlss, thats why I had to use it last time. Im gpu bound even at 1080pYou know it.
Vondel map, 1080P basic preset, no DLSS this time Bencher - native 1080P.
Show 0.1%/1% lows, plus average FPS. Bench full round from start to finish. Spectate until The end if you die early on.
Start capturing FPS data once the round begins and the plane appears on screen.
Use the 7900 XTX if you have one. If you’ve only got a 4090 use that. I’ve got the best of both worlds so can copy either.Which card you using? 4090 gets creamed without dlss, thats why I had to use it last time. Im gpu bound even at 1080p![]()
Why would I have a 7900xtxUse the 7900 XTX if you have one. If you’ve only got a 4090 use that. I’ve got the best of both worlds so can copy either.![]()
No, get that DLSS filth off. No sane person uses that in Warzone. 1080P native, 4090 I’ll run the same with my 4090.Why would I have a 7900xtx
Ok lets go 4090 with DLSS Q basic preset.
Tomorrow ill upload, now it's time to sleep. Can we open a thread or were are we posting?
Ok, but that benefits me, it will lower your averages that will be much higher than mine.No, get that DLSS filth off. No sane person uses that in Warzone. 1080P native, 4090 I’ll run the same with my 4090.
That’s fine, the game looks bad enough as it is without making it even worse with using DLSS.Ok, but that benefits me, it will lower your averages that will be much higher than mine.![]()
Decided to skip sleeping to test. So, the new map is playing "fine". 180 fps average (mostly gpu bound, card was 98% usage almost always), 1% lows at around 130. Last time we tested 1% lows were at 150-160 but whatever, not a big difference.That’s fine, the game looks bad enough as it is without making it even worse with using DLSS.![]()
I’ll put in the 4090 today and see what I get. Guarantee AMDip guy won’t say anything though.Decided to skip sleeping to test. So, the new map is playing "fine". 180 fps average (mostly gpu bound, card was 98% usage almost always), 1% lows at around 130. Last time we tested 1% lows were at 150-160 but whatever, not a big difference.
So then I decided to go back to Al mazrah. Holy cow, I was stuck at 140 fps averages with 1% lows dropping to 90ies. I remember I was getting close to 270+ FPS on this map, what happened?
