Im pretty sure I get the same performance as a 7800x 3d on TLOUPossibly why you’re system is dropping 150fps to Matt with his 7950X3D
With Intel performance costs power, no way around that I’m afraid.
Οk copied your config file, seems to be working now. You have CAS enabled? Cause it has it enabled with your file.
FPS is a mess though, the new map is playing "fine", 198 fps average 130 1% lows, but Al mazrah is horrible, can't get over 140 fps average
Where is your config ill use it I have the exact same build as yours and get like 200-250 on al mazreh / new map on rebirth. I also game at 1440p have a GP 850 32" so maybe 1080p probably out the question?I checked my config and I have the resolution, refresh rate and HDR set to Auto.
// Fullscreen Resolution
Resolution:0.0 = "Auto"
So it will use whatever is the default resolution of your display. Set to 1080P and launch the game.
On the previous page dude. Just place it in your my docs cod > players folder.Where is your config ill use it I have the exact same build as yours and get like 200-250 on al mazreh / new map on rebirth. I also game at 1440p have a GP 850 32" so maybe 1080p probably out the question?
This is his config fileWhere is your config ill use it I have the exact same build as yours and get like 200-250 on al mazreh / new map on rebirth. I also game at 1440p have a GP 850 32" so maybe 1080p probably out the question?
Yeah, CAS makes spotting enemies easier and adds some detail to the textures. Don't have to use 100% if its too sharp though, can lower it to 50% or so.Οk copied your config file, seems to be working now. You have CAS enabled? Cause it has it enabled with your file.
FPS is a mess though, the new map is playing "fine", 198 fps average 130 1% lows, but Al mazrah is horrible, can't get over 140 fps average. Ill post videos later, but all in all im down 140 fps on averages compared to 6 months ago. They messed up something horribly
Im looking through youtube, specifically for al mazrah since that's the biggest problem, I see a 13900k @ 5.8ghz getting 140 average. I assume no memory tunning since that's how much Im getting on my stock 12900k. It seems to have started around a month ago.Yeah, CAS makes spotting enemies easier and adds some detail to the textures. Don't have to use 100% if its too sharp though, can lower it to 50% or so.
Yeah as I mentioned, performance has taken a hit from previous Seasons as they've added new maps, more buildings to the maps etc.
My performance is lower than it was before, but not massively. Intel CPUs seem to have fallen behind quite dramatically.
That's according to a dude I interact with on YT who has a 13900K and a 7950X3D and a 4090/7900 XTX.
I get better X3D results than him though, but I don't think he's done much memory tuning etc other than apply XMP.
That's the guy I interact with, he's good people.Im looking through youtube, specifically for al mazrah since that's the biggest problem, I see a 13900k @ 5.8ghz getting 140 average. I assume no memory tunning since that's how much Im getting on my stock 12900k. It seems to have started around a month ago.
Check this guy, that's exactly the performance im getting in al mazrah.
- YouTube
Enjoy the videos and music that you love, upload original content and share it all with friends, family and the world on YouTube.youtu.be
Ah lol, tell him to tune his ram my manThat's the guy I interact with, he's good people.![]()
Look in my config file, and edit this value. It's the number of CPU worker threads, maybe you can extract a little extra performance from changing it.After looking at my old videos, like the one below
- YouTube
Enjoy the videos and music that you love, upload original content and share it all with friends, family and the world on YouTube.www.youtube.com
the CPU was drawing 80 - 85 watts back then and got over 240 fps on average. Now it's drawing 65 watts and I get an average of 140. Seems to be heavily underutilized, e cores aren't used at all. They borked it
Im assuming the fps i get at 1440p then is about right on warzone right now 200-250 ill see how 1080p looks on the 32" GP850 hopefully it will be okOn the previous page dude. Just place it in your my docs cod > players folder.
I'm going to run some 1440P tests on the 4090 over the weekend. You should expect almost exactly the same FPS as I got at 1080P, as even with the 7950X3D the 7900 XTX/4090 are still CPU limited at 1080P competitive settings.Im assuming the fps i get at 1440p then is about right on warzone right now 200-250 ill see how 1080p looks on the 32" GP850 hopefully it will be ok
I will have a look later with your config. Do you have a 1080p monitor or just use that res on say a 1440p / 4k monitor?I'm going to run some 1440P tests on the 4090 over the weekend. You should expect almost exactly the same FPS as I got at 1080P, as even with the 7950X3D the 7900 XTX/4090 are still CPU limited at 1080P competitive settings.
You're on a hiding to nothing trying to make comparisons between your system and LTMatt's! His whole system including his OS and hardware will be optimised, so unless you can replicate everything down to the exact same OS and exact services he has etc, then it's a futile endeavour.You are getting 350 on a 4090? How? Mine is pegged at 200 fps without dlss.
Mine is as well, that's not the issue. The game is currently borked on Intel cpus.You're on a hiding to nothing trying to make comparisons between your system and LTMatt's! His whole system including his OS and hardware will be optimised, so unless you can replicate everything down to the exact same OS and exact services he has etc, then it's a futile endeavour.
I don’t use a stripped OS as I use my PC for work and issue reproduction. That means I use Win 11 22H2 latest build. I do however have a clean OS, and reinstall Windows every few months. All I have running is MSI AB/Rivatuner and Corsair iCue (which does steal cpu cycles but I need it for my CPU AIO) and the AMD/Nvidia driver packages with ReLive/ShadowPlay running when I upload my videos. ShadowPlay costs twice as much FPS as ReLive does too.You're on a hiding to nothing trying to make comparisons between your system and LTMatt's! His whole system including his OS and hardware will be optimised, so unless you can replicate everything down to the exact same OS and exact services he has etc, then it's a futile endeavour.
4K display but drop it down to 1080P/1440P sometimes.I will have a look later with your config. Do you have a 1080p monitor or just use that res on say a 1440p / 4k monitor?
Man, you running iCue? Did not expect that from youI don’t use a stripped OS as I use my PC for work and issue reproduction. That means I use Win 11 22H2 latest build. I do however have a clean OS, and reinstall Windows every few months. All I have running is MSI AB/Rivatuner and Corsair iCue (which does steal cpu cycles but I need it for my CPU AIO) and the AMD/Nvidia driver packages with ReLive/ShadowPlay running when I upload my videos. ShadowPlay costs twice as much FPS as ReLive does too.
