Virtual Desktop (PCVR) (All headsets)
I think it depends on your GPU brand.
Nvidia is better on Airlink, AMD on Virtual Desktop.
That's not the case. Nvidia is better on both. It's just that for AMD cards it's normally better to use Virtual desktop as you can pick the encoder to use(AMD is much better at HEVC than H.264)
However, For some of AMD's RDNA 2 and RDNA 3 cards things have improved for Airlink as they now use HEVC as the default and you can select 200 Mbps. However if you have an older AMD card or one that they haven't built a profile for yet, you will still be using H.264 when using Airlink.
Airlink goes up to 200Mbps, but to get that reliably you need a Wifi6 router and be line of sight to it.
It's an ASUS TUF Gaming AX5400 about 1 metre away and dedicated for the PC and VR unit.
Been looking into it a bit more. The Airlink PC menu comes up fine, although I'm not a big fan of it, but I can't see any of my PCVR titles there. I've just realised that I may have to check "unknown sources" the in filter menu. I was going to my desktop and then launching the game from the desktop Steam app and not the Steam VR app (at least I don't think I was).
I'll need to play around with it more, but it seems like an awful lot of steps compared to Virtual Desktop.
It'll never be as clear or have as little latency as a wired connection with the bitrate upped to 500. The same is true of Airlink. However it's plenty good enough for many games.
Thanks I just wondered if maybe wireless had surpassed wired on quest2, it used to be quite close.
never tried VD wired
but i don't think VD offers headlock mode
i will check the HMD side
but googling seems to suggest yes
Yeah, the mobile version definitely has it. I don't suppose many are buying the wired steam version these days.
Update - definitely has the headlock function with the option to select a delay or not, which is absolutely perfect for my current needs.
SO been looking at VD for a while as an alternate to airlink BUT am I right that you can't just use it wired from pc to headset, you have to connect to your router via ethernet?? My router is all the way downstairs. Anyway around it or shall I try and refund VD
