- 22 Dec 2006
- Around Town
Thats why he is on my ignore listSo, the OP has already posted they were on a budget to get the room in the great place it is now.
Then you in "great wisdom" then tells the OP he should spend The best part of upgrading to Nearly £18,000 worth of speakers
I fully expect you have not even heard this speaker set up, i doubt even more that you yourself could afford it. WTF do you think you are doing coming up with this sort of post time after time after time after time..............................you do know it makes you look the complete d**k head that you almost certainly are ?
