Has anyone seen the simulation video showing what the implosion would have looked like? Not sure it's safe to share but it's out there.
This one?
This one?
Why would it not be safe ? It's science and education, science and education is fineNo, there's one showing it as if there was a camera filing the actual vessel in the water.
LEAKED Titan Sub Transcript Shows Crew In Battle For Lives
Jeff Ostroff reviews the leaked Titan Sub Transcript which the internet is debating the authenticity of, to see if this scenario is real, and whether the Tit...youtu.be
That sounds quite a realistic transcript to me.
If that is true then I would guess that there was an early breach in the rear part of the hull containing the electrics. If water had seeped in near the surface then it wouldn't have caused an immediate implosion. The extra weight of the water could account for the faster than expected descent as well as the ineffective dropping of ballast mentioned in the transcript. Despite a breach perhaps the water in that rear section prevented a complete collapse, at least at first, because the pressure was equalised. It would also explain why the motors were seemingly running at low power due to an electrical failure. They mention switching from battery bank A to B but don't mention whether that actually changed any speed of ascent. Perhaps the banging noises could also have been electrical components failing as well as the hull about to fail.
Then the rest of the hull went.
OceanGate's former finance director reveals she quit when CEO Stockton Rush asked her to take the controls of the doomed Titan submersible after firing chief pilot who raised safety concerns
Afaik it was a completely separate compartment with a bulkhead between. Although you would hope they would have had some kind of leak detection or a camera in there?If it was leaking and that was the cause of this faster descent, why wouldn't they notice, or is the rear somehow separated from cockpit area?
Different bangs. The transcript refers to a lot of noise (I think they said bangs but might have used a different word), which the crew were worried about. This is all assuming the transcript is real of course.The "banging" noises were heard long after the suspected time of implosion^^ The noises were almost certainly unrelated to the implosion as the USCG guy said in the press conf later.
That sounds like too much common sense to be applied by this CEO.Although you would hope they would have had some kind of leak detection or a camera in there?
There was a partition with a tv screen and all the electrics behind that wall, there's some clips where you can see Stockton working on the stuff behind the partition, I don't think it was leaking, they would have noticed and a leak at that depth would be catastrophic without giving them time to go through that transcriptI get the feeling that's not fake and the transcript is being passed around privately between inside people.
