I’m not sure as I don’t have either but you’ll see a difference if your SSD’s and CPUs at both ends can handle it. I looked into it once and once I’d priced it up I stuck with 1gb
Due to SMB, I wouldn’t expect the full 10gb even if everything supported it.
10 GbE is relatively easy to max out, as a lot of NIC have hardware offloads to reduce CPU overhead.
Here is one example which I posted a while ago:
