Caporegime
- 29 Aug 2007
- Auckland
@Angilion dropping truth bombs in your bunker.
Why do you keep bringing up aliens? No one here is saying its Aliens. Nothing in FLIR videos contradicts the statements in fact they back up the statements. The report is the pilot was being effected by ECM and the FLIR video shows the object with the same message on screen as though ECM is active.Nothing in the video’s or what’s described in the statements are blocking these radars. What’s shown in the videos contradicts the statements so has to be aliens. If only we had any evidence at all to support the statements. Sadly we don’t. Just videos of what is most likely a ballon, bird and plane acting as expected.
“I’m not saying it’s aliens, I’m just saying it’s probably a manned or unmanned vehicle that doesn’t match the technology any country professes to have”![]()
How can you know the object is not blocking the radar? It seems like your just making that up like you are that you can see flapping wings or aviation lights which is clearly not true by anyone that has watched the FLIR video. There are no flapping rings and there are no aviation lights.
The report is the pilot and weapon officer locked onto the object. Right after they locked onto the object they got hit by ECM losing radar lock, range finder and weapon lock and we can see the range finder in the video. Which is what we would expect to happen from a craft as a craft (plane or unmanned drone) would detect the weapon lock and bring up an alert. ECM is one of the main defence methods when you are under threat from a weapons lock. If ECM is activated that would also explain the unclear movements and impossible movements as they are not gettering a proper sensor readings.
So instead of believing the simple solution that its some sort of craft triggering ECM after a active sensor lock was put on it and the ECM is confusing sensors. Which I would point out the pilots reported estimating the object was 12 meters in size and oval in shape which would be the right size for a military unmanned drone from the right point of view. Instead you want us to believe its some bird or balloon that 12 highly trained people in fighter jets and 6 navy ships cannot tell is a balloon or bird. Along with by shear fluke some unknown force takes out the ranger lock, radar and weapons lock right as they get an active sensor lock on the "Bird". Your idea of its a bird or balloon sounds as crazy to me as saying its aliens.
The reports are not highly suspect though what you are saying about a bird is highly suspect. Senior Chief Kavin Day, Patrick Hugues Petty Officer (Technician), Petty Officer Gary Voorhis, Senior Chief Kavin Day, Commander David Fravor, Aex Dietrich and Commander Chad Underwood and all the others are massively more reliable then you.The pilots both had a lock on the targets, no blocking or focused interference, the jets had a lock on the bird and balloon.
To block maybe a dozen radar systems some ship based would take a huge amount of power. To generate that power would take huge systems burning huge amounts of fuel and producing huge amounts of heat. That only realistically leaves ship or ships based systems. Unless alien tech of course, then sure, antimatter engine craft the size of a plane maybe.
Maybe someone has a secret fleet of Vulcan bombers or something, but those would just light up the radar as far as it could scan, and these things seemed invisible.
The simple solution is the videos are as they seem. The reports are highly suspect.
That makes more sense then thinking its a bird that the pilots mistake as a 12 meters drone like object that disables sensors the same as how how ECM functions. Or you know its a classified 12 meter drone with an ECM pod. Though I am sure the people on this forum are right its not a 12 meter drone with an ECM pod and in fact all the ships, fighter jets, sensor systems and crew are confused by a bird. The 12 meter object with a drone like oval shape reported as been seen was in fact a tiny bird. Having never seen a bird before the crew panicked and at the same time the fighter jet locked onto the bird with active sensors due to having of course never seen a bird before the sensor systems had a melt down for no apparent reason. Not because of ECM but because the bird did a fly by.“I’m not saying it’s aliens, I’m just saying it’s probably a manned or unmanned vehicle that doesn’t match the technology any country professes to have”![]()
Since when are modern day Stealth and ECM systems limited to 1 single target. I think your just speaking rubbish and making things up like you did when you made up the nonsense about you seeing flapping wings and aviation lights which is clearly not true. This huge amounts of fuel and producing huge amounts of heat is just more made up nonsense that's not how modern systems work.
Anyway as far as I remember from the reports everyone was using passive sensors. Only 1 plane switched to active sensors and only 1 planes active sensors got hit by ECM. That gets around your fake huge systems burning huge amounts of fuel and producing huge amounts of heat.
What do you mean that didn’t happen? Isn't that just was the witnesses described, the object was being lost and regained as they struggled to maintain a lock with passive sensors. Just like Stealth would when it blends into background.“Stealth is not the same. That’s about defeating radar by blending into background noise. However, in this case that didn’t happen low power passive systems easy picked up the bird and ballon.”
As I said before I don’t remember the witness's saying the navy ships radar was being blocked by ECM. As far as I recall only 1 fighterjet had its radar blocked the same fighter jet that activated locked onto the target. The simplest explanation is the object picked up the weapon lock and as a defensive measure targeted ECM back at the single fighter jet. Isn't there also a 2nd type of ECM that instead of blocking makes false readings and you appear in multiple places which would explain the impossible movements if its a false reading.“To block radar you have to flood the collector with more spam than it’s sending. An aircraft carrier is spamming megawatts. Many ships are spamming many more megawatts. Those need spamming too. Not happening without the help of little green men IMO.”
Isn’t the thermal temperature of the object massively too hot to be a bird or balloon? Birds and Balloons don’t give out that much heat. On the other hand a drone or plane would put out that high a thermal temperature.“A hunch I have, is non of the radars had been set for cormorants or plastic balloons (why would they be?) and the visual sightings caused some confusion resulting in planes being sent to search the area with radars better suited to imaging low cross section objects.“
No he isn't as clever as he is.
I believe that how the Universe is made lends itself to creating life wherever it can, what I don't believe is that it has created other intelligent life that could reach us.
It would be a complete and utter waste of all those ingredients if some form of life wasn't on another planet somewhere.
You've also got to be some special kind of doomsayer to believe that only this rock has got some type of life on it.
The subject of technology advancement is interesting.
When a technology is created that is so far away from current technologies, so it appeared with no public evolution, then it does tempt the question of how it comes into existence.
I find it interesting that some of the technology today was only seen in fiction in the past.
The gadget I'm waiting for is a device which scans a person and instantly tells the operator all the mineral and vitamin levels the subject has.
I can't think of a good example off the cuff without me going back researching it. But an example we could say today is quantum computing.Can you give an example? Preferably recent, to rule out the possibility of the related prior knowledge having been lost to history.
Someone has to think of the idea first. Sometimes the same person who invented the technology, sometimes not. Sometimes the person who invented the tech was inspired by the person who thought of the idea. Mobile phones come to mind - the person who invented the first one was quite open about the fact that they got the idea from Star Trek.
How have we made it possible to go from 1 OR 0 in binary to now be 1 AND 0?
Why do we think there is a long gap between some ideas and the technology? I can understand having a practical version of it can be decades away. But what changes a thought for it to become real?
For example I've seen VR (virtual reality) as an idea. Then it became a reality in the early 90s (I saw it on a tv show called Cyberzone). But it's not until recent years its become a practical home device. From reality to practical use there was always progress. But some ideas seem to be an idea with nothing happening and then appear decades later.
Who was that? Because the concept of mobile phones and wireless technology came about from Nikola Tesla. He spoke and wrote of a world where power and communication happens over the airwaves. His inventions are what every piece of tech we use today employ at their core. For all intents and purposes, if Tesla had the continued funding and didn't get blind sided by Thomas Edison with false claims to ruin his public image, he'd have created the first devices.
When I was at college we had a class that went on for a slot of 3 hours per week. They had us making a calculator using binary code, 1's and 0's. Apparently computers can't subtract so we had to do different calculations if we wanted a subtraction answer. But I can honestly say after that class I came out of there mentally tired. I've never felt tired like that before. My brain was doing over time and only just keeping up. So I can't begin to imagine the complexity of quantum computing. I'll keep with the abacus!I think the same applies. Quantum computing was an idea, then it became a reality and maybe at some point in the future it will become a practical home device. I don't know why there was a long (by modern standards) gap between the idea and the first working implementation of the idea, but that's probably because I don't understand quantum physics. Come to think of it, was it a long time? A quick look indicates that the idea was first put forward in 1980 and the first working device was in 1998. Maybe the time period from the first general purpose computer (1942 IIRC...nope, 1943) to the idea of a quantum computer is a long period of time by modern standards. My quick look turned up an interesting possible explanation - there was very little overlap between people who were developing computers and people who were quantum physicists.
