Don’t get too excited, that page very rarely works for me and when it does its full price.just got some offers from VM, that they said would list on my account, where about's do you find the offers page?
On the web chat waiting again to try and to pretend to cancel and notice there is an offers page on my account which is £25 for 350mbit (250 + Volt although I ditched the O2 sim a few months ago :shrugwhich doesn't seem bad considering I was paying £30 before. When phoning before they didn't seem to do anything less than 18 months contract now which is annoying as should be a couple of other options for FTTP for the first time coming up.
I'd guess the rolling contract is more? I'm not sure of the ETA of other builds around here, there is Youfibre who have done what it sounds like they've done in other areas and just wire up one or two streets, Open Reach have a few road works planned but nothing on their site with a date but Truespeed have started recently which are most likely the best bet out of them. The same as you though luckily my area for VM is actually okay so its not terrible but lower pings and quicker upload for work would be handy.I just signed up post above yours to an 18m contract, but my area is still unknown on fttp rollout, hopefully by end off my contract BT or community fibre will be around here.
By the way VM offer 30 day rolling contracts. If you are out of contract you should be able to go onto a rolling contract.
I did above via what’s app, but when we were out of contract at start of year we phoned up retention line and went onto the 30day rolling, but now back into 18m after negotiating the above.
Yes I think the higher tiers get the hub 4 and 5 until they have more of them in stock maybe? The volt thing should self activate after a few days or so, else give them a nudge, I can't remember if it just needs to be the same address or if the account name has to match as well, have a feeling matching address is enough.Signed up and they sent a hub 3. I guess the lower 132mb tier don't get the newer hubs. My sister is signed up to O2 so I wonder if the Volt stuff still applies.
Anyone got o2 SIM card plan ?
I switched to a volt package and got sent a new o2 SIM card in the post, in the meantime I got a text on my old vm SIM card saying text SWAP to 20220.
Im lost, lol. Do I do this now on my old virgin mobile sim or when I have the o2 sim in my phone?
I'm on 80.192.24.0/22 and get ~16ms to London, ~6ms on OR FTTP depending on which peer I end up on.Has anyone noticed their connection varies quite wildly depending on which IP address/range they get? For example, on 86.8.0.0/17 (iirc) I was pinging Cloudflare/1.1.1.1 around 12ms and had great latency (for VM) to almost everyone. Outliers were Quad9 (28ms) and Oracle's network (28-30ms).
Since I swapped back to VyOS, I picked up a new IP in the 80.194.132.0/22 range. Latency is absolutely awful (double or worse, across the board), and my TBB graph is a car crash compared to before, even with fq-codel. I'm now going to have to play around with spoofing the WAN interface's MAC to get a new IP in a 'better' range. Has anyone else noticed this?
I think it's actually a local issue. I've just spoofed an old MAC and rebooted the Hub, and still:I'm on 80.192.24.0/22 and get ~16ms to London, ~6ms on OR FTTP depending on which peer I end up on.
user@vyos:~$ ping 1.1.1.1
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 ttl=53 time=36.9 ms
64 bytes from 1.1.1.1: icmp_seq=2 ttl=53 time=33.7 ms
64 bytes from 1.1.1.1: icmp_seq=3 ttl=53 time=34.7 ms
64 bytes from 1.1.1.1: icmp_seq=4 ttl=53 time=34.8 ms
64 bytes from 1.1.1.1: icmp_seq=5 ttl=53 time=26.7 ms
64 bytes from 1.1.1.1: icmp_seq=6 ttl=53 time=25.8 ms
^C
--- 1.1.1.1 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 15ms
rtt min/avg/max/mdev = 25.791/32.103/36.876/4.242 ms
Fingers crossed it's temporary.Time to play the 'wait a week to speak to someone who tells you to restart the Hub and then disconnects you while transferring the call'. I think I'll just post on their forum and wait (and wait).
root@UDM-SE:~# ping -I 80.192.27.xx 9.9.9.9
PING 9.9.9.9 (9.9.9.9) from 80.192.27.22 : 56(84) bytes of data.
64 bytes from 9.9.9.9: icmp_seq=1 ttl=57 time=18.0 ms
64 bytes from 9.9.9.9: icmp_seq=2 ttl=57 time=18.5 ms
64 bytes from 9.9.9.9: icmp_seq=3 ttl=57 time=17.6 ms
64 bytes from 9.9.9.9: icmp_seq=4 ttl=57 time=18.4 ms
64 bytes from 9.9.9.9: icmp_seq=5 ttl=57 time=17.2 ms
64 bytes from 9.9.9.9: icmp_seq=6 ttl=57 time=18.0 ms
64 bytes from 9.9.9.9: icmp_seq=7 ttl=57 time=16.4 ms
64 bytes from 9.9.9.9: icmp_seq=8 ttl=57 time=16.7 ms
64 bytes from 9.9.9.9: icmp_seq=9 ttl=57 time=16.6 ms
64 bytes from 9.9.9.9: icmp_seq=10 ttl=57 time=16.4 ms
	root@UDM-SE:~# ping 9.9.9.9
PING 9.9.9.9 (9.9.9.9) 56(84) bytes of data.
64 bytes from 9.9.9.9: icmp_seq=1 ttl=59 time=5.18 ms
64 bytes from 9.9.9.9: icmp_seq=2 ttl=59 time=5.01 ms
64 bytes from 9.9.9.9: icmp_seq=3 ttl=59 time=5.11 ms
64 bytes from 9.9.9.9: icmp_seq=4 ttl=59 time=5.21 ms
64 bytes from 9.9.9.9: icmp_seq=5 ttl=59 time=5.09 ms
64 bytes from 9.9.9.9: icmp_seq=6 ttl=59 time=5.23 ms
Code:root@UDM-SE:~# ping -I 80.192.27.xx 9.9.9.9 PING 9.9.9.9 (9.9.9.9) from 80.192.27.22 : 56(84) bytes of data. 64 bytes from 9.9.9.9: icmp_seq=1 ttl=57 time=18.0 ms 64 bytes from 9.9.9.9: icmp_seq=2 ttl=57 time=18.5 ms 64 bytes from 9.9.9.9: icmp_seq=3 ttl=57 time=17.6 ms 64 bytes from 9.9.9.9: icmp_seq=4 ttl=57 time=18.4 ms 64 bytes from 9.9.9.9: icmp_seq=5 ttl=57 time=17.2 ms 64 bytes from 9.9.9.9: icmp_seq=6 ttl=57 time=18.0 ms 64 bytes from 9.9.9.9: icmp_seq=7 ttl=57 time=16.4 ms 64 bytes from 9.9.9.9: icmp_seq=8 ttl=57 time=16.7 ms 64 bytes from 9.9.9.9: icmp_seq=9 ttl=57 time=16.6 ms 64 bytes from 9.9.9.9: icmp_seq=10 ttl=57 time=16.4 ms
Not great tbh for an idle connection!
Via Aquiss:
Code:root@UDM-SE:~# ping 9.9.9.9 PING 9.9.9.9 (9.9.9.9) 56(84) bytes of data. 64 bytes from 9.9.9.9: icmp_seq=1 ttl=59 time=5.18 ms 64 bytes from 9.9.9.9: icmp_seq=2 ttl=59 time=5.01 ms 64 bytes from 9.9.9.9: icmp_seq=3 ttl=59 time=5.11 ms 64 bytes from 9.9.9.9: icmp_seq=4 ttl=59 time=5.21 ms 64 bytes from 9.9.9.9: icmp_seq=5 ttl=59 time=5.09 ms 64 bytes from 9.9.9.9: icmp_seq=6 ttl=59 time=5.23 ms
user@vyos:~$ ping 1.0.0.1
PING 1.0.0.1 (1.0.0.1) 56(84) bytes of data.
64 bytes from 1.0.0.1: icmp_seq=1 ttl=53 time=19.2 ms
64 bytes from 1.0.0.1: icmp_seq=2 ttl=53 time=16.7 ms
64 bytes from 1.0.0.1: icmp_seq=3 ttl=53 time=38.8 ms
64 bytes from 1.0.0.1: icmp_seq=4 ttl=53 time=19.3 ms
64 bytes from 1.0.0.1: icmp_seq=5 ttl=53 time=18.4 ms
64 bytes from 1.0.0.1: icmp_seq=6 ttl=53 time=18.7 ms
64 bytes from 1.0.0.1: icmp_seq=7 ttl=53 time=36.2 ms
64 bytes from 1.0.0.1: icmp_seq=8 ttl=53 time=18.9 ms
^C
--- 1.0.0.1 ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 20ms
rtt min/avg/max/mdev = 16.736/23.283/38.750/8.250 ms
	eth0 redirect to the dummy ifb0 interface is suddenly causing lag).
 I swear someone, somewhere, is messing with me. Shouldn't be long now, hopefully. I've already been chatting with the CEO of Aquiss, and discussed networking and an IP block allocation etc. I'll literally place an order the second it's live, and then add in Netomnia when they (finally) turn up. For now, I'm the definition of frustrated. My wife thinks I'm nuts. She's probably right!Are you sure there isn't a letter in there somewhere telling you what to do? There nearly always is. I would read that as sending the text on your old SIM card, then swap to the new SIM.
traffic-policy {
    shaper qos-down {
        bandwidth 800mbit
        default {
            bandwidth 800mbit
            burst 15k
            queue-limit 1000
            queue-type fq-codel
    shaper qos-up {
        bandwidth 85mbit
        default {
            bandwidth 85mbit
            burst 15k
            queue-limit 1000
            queue-type fq-codel
64 bytes from 1.0.0.1: icmp_seq=1 ttl=53 time=19.4 ms
64 bytes from 1.0.0.1: icmp_seq=2 ttl=53 time=19.6 ms
64 bytes from 1.0.0.1: icmp_seq=3 ttl=53 time=19.6 ms
64 bytes from 1.0.0.1: icmp_seq=4 ttl=53 time=21.7 ms
64 bytes from 1.0.0.1: icmp_seq=5 ttl=53 time=19.5 ms
^C
5 packets transmitted, 5 received, 0% packet loss, time 12ms
rtt min/avg/max/mdev = 19.421/19.951/21.697/0.883 ms
