I finally got round to using my Dewalt set of bits and as said the PZ2 got a hammering due to my eyes -My right eye has no vision in the centre so when I put a screw in bit it looks straight - look at it from another angle and it's 10 deg out - So a few rounded bits today.Absolutely. 99% of the time you are going to be using PZ2, and they don't last forever, so a big box of them is a solid purchase.
I buy the sets to keep at the bottom of the toolbox for those really weird times when it's not PZ2 !!
Impact drivers are the same, imo. They are first fix tools, so mine has sat at the bottom of the toolbox completely unused. The only reason I don't sell it on eBay, is they are useful for removing stubborn screws.
These are great. I've got a couple of them and one just stays in my drill driver all the timeIf you set the screw up in one of these first
Wera Impaktor 1/4" Hex Magnetic Bit Holder 75mm - Screwfix
Order online at Screwfix.com. Impaktor bit holder with ¼" hex drive, retaining ring and magnet, designed to meet the extreme requirements when working with impact screwdrivers. TriTorsion system is designed to absorb impact forces and thereby protect the bit tip, greatly enhancing the service...www.screwfix.com
You should have less issues. It might not help with the blind spot & not putting them in straight but they will always be engaged so will minimise camout
F1 sponsorshipSeems like a strange combination. DeWalt and McLaren.
They always push the sets as well, and I am not sure the average person has much need for the impact driver.
I suppose they need to find some way to pay for the little badges on the sides of the cars. I remember reading the costs for different positions on the driver/car years ago and it was ridiculous back then. Must be very lucrative now
Sorry for necroposting but I am a footpath warden who also runs work parties to maintain public rights of way. After doing research I bought Makita 18v tools and use them with the twin charger and 5ah batteries.I'm still looking for a brush cutter / line trimmer and after reading up feel the 36v Makita platform is probably a better fit than the 18v offerings. I'm torn now between
Makita DUX60Z Split Shaft + Brush Cutter Attachement (300mm cutting diameter) = £220ish without batteries
or
Makita DUR368LZ Twin 18V (36V) Li-ion LXT Brushless Brush Cutter (350mm cutting diameter) = £200ish
The idea of the split shaft is attractive, but the attachments are pretty pricey. For twenty quid difference though it might give me further options down the line, versus the single tool. Any thoughts, would be great to hear from anyone who has used them both etc.
Hi all, another mitre saw recommendation, will be mainly used for skirting boards, they're tall at 19.5cm (7.67 inches)
I managed to get away without in one room, but the mitre box was not tall enough, there a few smaller diy tasks it would be swifter for also.
So my research tells me crosscut is key, I nearly got an Einhell inthe prime sales but a few reviews had the cover shattering after minimal use.
Evolution R210SMS+ 210mm Sliding Compound Mitre Saw (230V) - Machine Mart
www.machinemart.co.uk
So, I have been looking at the above, budget is £200.
Nice, now this is the one I nearly went with on Amazon as specs seem better.looks to be a better option to meEinhell TC-SM 2131/1 210mm Dual Bevel Sliding Compound Mitre Saw (230) - Machine Mart
This isnt a tool, its a kit but it seems a good one and I've seen some bad plaster repaired a bit like this. USA kit, so anyone seen a UK version of this :
I'd have to research circular saws then though!If it's only for skirting boards and the odd job, I'd use a circular saw and a square rather than splashing on another bit of kit.
